Skidding distance
Started by jim king, August 23, 2010, 09:36:11 AM
Stan snider
Where there is so much water I cant help but think of a canal or flume, that is if the terrain would support it.  Stan
pasbuild
What size load will these units haul both volume and weight, also what is there rate of travel? just curious how much you will get out to the river with one operator and two gal. of fuel per day.
If it can't be nailed or glued then screw it
Seems to me, your back at square one. With the same machines you were using back some time ago with the same question. ;)
jim king
QuoteSeems to me, your back at square one. With the same machines you were using back some time ago with the same question.
I think you are right.
The little ones will bring out an average of 30 - 6" x 8" by 50" cants and the big one over 50.  They are not fast but at 4 miles they can make up to 5 round trips a day in 10 hours.  The good thing is that the road is reusable it seems forever.
The bad thing is that the road has to be cleaned well or the rubber tracks can be damaged by pointed small stumps.  Especially if you turn on top of one.  They can be repaired but it takes a day each time they break.
I forgot to mention earlier that the majority of species we work with don´t  float.
Stan snider
"I forgot to mention earlier that the majority of species we work with don´t  float."
:(That seems to sink my ideas then :(
Okrafarmer
Any way to pull a small trailer and, maybe, double your capacity per machine?
Now selling Logrite tools!
jim king
The machines are about at capacity and anything with wheels is a problem.
pasbuild
I would think that an ATV set up with a trailer would have no problem on the road pictured, even the wet area if the bottom is solid would be no problem and you could cut your run time in half.  I would think that 10 to 35 mph would be a safe speed depending on road conditions. How long would it take to pay down your investment with an additional 150 cants per day?
Don't bet on it.
That sort of wet soil tends to turn into "Tarzan" type quicksand if it's disturbed. The little rubber tracked crawlers have such a low ground pressure they can stealth over it without churning it up. Even an ATV, especially with a load, would churn it into sludge. I also suspect there is no hard base underneath.
I've had to haul ATVs, tractors, trucks and even bulldozers out of that sort of stuff.  :D
Ron Wenrich
What did you use to make the road?  All hand work?
Mooseherder
This is my Brother's machine.  It'll go where ever you want it to. ;D
And it's yeller. ;)
Stan snider
I never knew such a machine existed. Does it have power steering? Stan
jim king
Shovels, picks, axes, chainsaws and wheelbarrows.
QuoteThat sort of wet soil tends to turn into "Tarzan" type quicksand if it's disturbed. The little rubber tracked crawlers have such a low ground pressure they can stealth over it without churning it up. Even an ATV, especially with a load, would churn it into sludge. I also suspect there is no hard base underneath.
You got it exactly, my dad called it loon s--t.  no bottom.
QuoteThis is my Brother's machine.  It'll go where ever you want it to.
That looks to be an expensive big boys toy.  Nice, are the tracks metal ?  Maybe metal tracks could be made for the little tracked ,machines to replace the rubber tracks.
Mooseherder
Yes, the tracks are rubber.
It's just a 4 wheeler with tracks.  Just a simple bolt on.
I think the tracks were around 3 grand new for the set.
Member Sprucebunny has a set on her machine also.
pasbuild
As a kid I used to go to camp with my uncle who has 160 acres in the largest swamp in Michigan, the Cyr swamp is every bit as difficult as any other swamp and to get to camp he and his father made a swamp buggy out of an old model A pickup truck. They replaced the front end with a straight axle, added several bogie wheels on each side and made tracks for it. It was the only thing that was going to get you in there in the warm months, maybe you need to invent/ fabricate your ideal machine.
treefarmer87
i moved into a new spot today. the drag is longer than what i like, it is about 500-800 yrds from my loader. the road is too narrow to take the loader or truck down so i have to leave it up in the field, and drag up from the swamp
1994 Ford L9000
2004 Tigercat 718
1998 Barko 225
1999 John Deere 748G
FEC 1550 slasher
CTR 314 Delimber
Sthil 461
Sthil 250
