Author Topic: Chainsaw Holder/rack  (Read 12605 times)
Offline sdunston
  • New York (the great tax state)
« on: July 22, 2012, 08:55:59 AM »
I have been looking for a holder or rack to mound on a tractor or atv to hold my chainsaw so it don't bounce all over. Any suggestions of brands or ideas on making
thanks Sam
WM LT28, American fordge 18x8 planer,Orange and white chainsaws, NH TC33, IHT6 dozer, IH-H tractor and alot of other stuff that keeps me agravated trying to keep running
Offline Bogue Chitto
Re: Chainsaw Holder/rack
« Reply #1 on: July 22, 2012, 09:08:16 AM »
I took a 2 x 6 and plunged cut into two inch side.  Bolted board to tractor then stuck saw in the hole.
Online beenthere
« Reply #2 on: July 22, 2012, 11:36:54 AM »
There are some previous thread(s) with different ideas. I made a sandwich of two pieces of plywood and bolted to the ROPS.
Also,
http://www.forestryforum.com/board/index.php/topic,56509.msg818807.html#msg818807
Offline Bobus2003
« Reply #3 on: July 22, 2012, 12:00:47 PM »
I bought one of these.. Used it about twice.. but i like it
http://www.kolpinpowersports.com/products/bow-cases-carriers/saw-boot-2.html
Offline sdunston
« Reply #4 on: July 22, 2012, 02:10:30 PM »
Thanks guys, I like........
Sam
Offline shinnlinger
« Reply #5 on: July 25, 2012, 10:22:47 PM »
I made a scabbard out of plywood and screwed it to my fender.  Pics are in my gallery.  I'm on my phone so I can't post them right now
Shinnlinger
Offline shinnlinger
« Reply #6 on: July 26, 2012, 07:41:31 AM »
Shinnlinger
Online beenthere
« Reply #7 on: July 26, 2012, 11:05:11 AM »
shinlinger
That is an interesting assortment of tools and such hanging on there. Mostly used when getting logs outta the woods?
Is the bright yellow in the pic a chain cover that is new? or something else near the saw?
Offline Ironwood
    • http://www.branchandburl.com
« Reply #8 on: July 26, 2012, 11:37:40 AM »
I recognize the winch  ;D. I miss that girl. Also, the hubs in my Gator are frrom YOUR old truck, too funny.
 Here is my solution, it is removable and can go on other equipment with the same box tube mounts as on the Gator. The grey in between the steel channel is stiff rubber. Knobs are off an old woodworking machine I scrapped.
Offline shinnlinger
« Reply #9 on: July 26, 2012, 08:06:11 PM »
The yellow chainsaw is the Partner Yellow of my trusty old F-55.
My winch setup is something I threw together very quickly this winter to skid logs of my frozen beaver pond when I realized the standing dead maple were bone dry and prime for the woodstove.  As Sanford and Sons as it looks it did get the job done.
That old Warn still pulls its weight thats for sure....
Dave
Shinnlinger
Offline UN Hooker
« Reply #10 on: July 26, 2012, 08:43:58 PM »
 The "Ballast" holding the roof down on the building is neat! :D  :D
Retired Toolmaker/Moldmaker
C-4 & C5D TF - 5500 Iron Mule - Restored 4400 Ford Ind. FEL ex Backhoe w/custom built boom w/Valby 360* grapple w/18' reach - 920 Cat w/bucket & forks w/clamp - Peterson 10" WPF - LT-15 - Cooks Catsclaw & Dual tooth setter - many Husky saws
Offline shinnlinger
« Reply #11 on: July 26, 2012, 09:14:51 PM »
I ran out of screws and had to do something.
Shinnlinger
Offline kantuckid
« Reply #12 on: July 26, 2021, 09:12:21 AM »
Thread revival
Prospecting for more ideas.
I've read through this thread and lean toward building a plywood scabbard fastened to my tractor ROPS or maybe behind the rear OE tiny toolbox where a safety sign might go.
In looking at various online, made for sale saw holders, I see several and most are pricey. The Kolpin 20044 is  a clamp style that I like. Amazon review says that a vertical Stihl leaks out bar oil.
I see concerns about bar strain from vibration carried on a tractor. How does that play out from long term users?
Is that really more strain than what's created in regular use in a cut? I saw one version made for use inside a PU truck bed that holds the saw horizontal within nylon U channels for the bar/chain.
Offline Tacotodd
  • To learn and help
« Reply #13 on: July 26, 2021, 09:21:22 AM »
Just for giggles, check out the tool that Madsens has for a saw holder. It might give you some ideas & maybe not. Only way to know is to look.
Trying harder everyday.
Offline PoginyHill
  • Gentleman logger
« Reply #14 on: July 26, 2021, 09:52:59 AM »
I attach mine to the FEL mounts. I remove my loader during the winter when I use the saws. Perfect for my use. Out of the way and well protected. One for each side.
Kubota M7060, Cat E70B, Case 310, 750 Grizzly ATV, Wallenstein FX110, 84" Landpride rotary hog, Classic Edge 750, Stihl 170, 261, 391
Offline Old Greenhorn
    • Woodsman Forest Products
« Reply #15 on: July 26, 2021, 10:44:49 AM »
Well I had the same issue a while back and made my own for 2 reasons: A) I didn't see the cost as being worth it, and 2) I didn't like the bar pinch method with a clamp to hold the saw, I too felt this put a lot of load on the bar. SO I made one up that lets the felling teeth take the weight of the saw. I had a little thread on it a few years back: https://forestryforum.com/board/index.php?topic=104840.msg1630873#top
 It's still working just fine. I don't have any leakage issue and the saw lives their 90% of the time. My 372 leaks oil no matter what position it is in, but I only pull that saw out when I need it. My 50cc never leaks a drop.
 I'd rather build than buy anytime I can.
Oscar 328 Band Mill, Husky 450, 372 (Clone), Mule 3010, and too many hand tools. :) Retired and trying to make a living to stay that way. NYLT Certified.
OK, maybe I am the woodcutter now.
I can work with wood, but I am NOT a Woodworker, yet.
Online mike_belben
  • Pulp Friction
« Reply #16 on: July 26, 2021, 10:51:17 AM »
:D :D :D
Isaiah 63:10
Offline Grizzerbear
« Reply #17 on: July 26, 2021, 11:05:38 AM »
There are some great DIY ideas here. If you decide to go the other route and buy one, Sawhaul is a homegrown small business that makes a fine product. I haven't had any negative issues with the saw being stored in that position.
<br
Online btulloh
HM126
Online Roundhouse
« Reply #19 on: July 26, 2021, 12:29:28 PM »
I end up moving my saw around a lot, from the workshop into the truck, from the truck to the sawmill shed, from the shed to the tree or from the shed to the four wheeler to the tree, and all the steps in reverse until the saw is back home in the workshop again. It was getting real tiresome dragging along a basket of supplies in addition to the saw + a gas can. I don't saw that much so a gallon lasts me a while. I built this small wooden platform around the base of the saw with a dedicated place for the gallon of fuel, quart of bar oil, chain file, scrench and an exta container of mix oil. The green bungee attaches the saw to the base snugly enough that I carry the whole works using the saw handle. It works great and keeps everything together in one trip, I always have everything I need at the tree where I'm working. In my situation I'm traveling to where I cut on the four wheeler, sometimes the truck, distances are relatively short so I'll go back and pick things up with the tractor, skid steer or forklift once I'm done cutting.
Woodland Mills HM130, 1995 F350 7.3L, 1988 F350 dump, Owatonna 770 rough terrain forklift, 1938 Allis-Chalmers reverse WC tractor loader, 1979 Ford CL340 Skid Steer, 1948 Allis-Chalmers B, 1988 Yamaha Moto-4 200, various chain saws
Firewood holder
Started by marine5068 on Firewood and Wood Heating
Last post July 28, 2015, 07:41:10 AM
by Theo
planter holder
Started by Dave H. on General Woodworking
Last post September 18, 2016, 03:46:10 PM
by Savannahdan
Dog Bowl Holder
Started by lowpolyjoe on General Woodworking
Last post January 15, 2016, 10:49:03 AM
by lowpolyjoe
3 ring pot holder
Started by grouch on General Board
Last post July 30, 2017, 11:57:14 PM
by grouch
