Time at Jeff's house
Started by Reddog, January 15, 2010, 10:10:41 AM
Those oak blocks was all I wanted to lift into that trailer. I was doing ok until Wally made me quit using his fender for my clean and jerk cause I bent it, so we had to go to a two person dead lift. :)
Kevin
QuoteWell stopped in to see Jeff and Tammie today.
He made me leave with another load of wood
Good thing you just happened to have the empty trailer with you. ;D
I won't have to wear my hard hat at the pig roast this year.
Did you find some iron in there?
Reddog
Missed the iron, it was two 1/2" threaded rods that could be seen. That black was from just above one.
Did hit the dirt once in that very cut though :-X Then had to do a little filing. :)
The way this is going, I may take a trailer every time I go to Jeff's. :D
Reddog
Well Jeff I found the nails I hit, we just needed to look at the other chunk.
So do you want your iron back.
isawlogs
     They have Jeff written all over them ,  ;D
   Marcel
They could be a door prize at the Pig Roast  :D.
Coon
Jeff will probably surprise all of us and use that metal in some kind of project.  ;)  :D  :D
Coon
Awe c'mon Jeff you might need them some day.... they are even one of a kind.  :D  :D
