Author Topic: Diesel or Soap Water  (Read 1880 times)
Offline YellowHammer
  • Take Steps to Save Steps
    • Hobby Hardwood Alabama
Re: Diesel or Soap Water
« Reply #20 on: October 12, 2021, 02:01:23 PM »
Iíve tried diesel in mine, and I canít turn the Lubemizer down enough.  It smells like an old spill.  Iím going to try some smaller diameter spray nozzles.
YellowHammerisms:
Take steps to save steps.
If it wonít roll, its not a log; itís still a piece of tree.  Sawmills cut logs, not pieces of trees.
Kiln drying wood: When the cookies are burned, theyíre burned, and you canít fix them.  Donít burn the cookies.
Offline KenMac
  • I'm new, but don't feel so new!
« Reply #21 on: October 12, 2021, 08:16:51 PM »
I certainly am not an expert on my own mill , much less a WM, but I think the Cook's felt rub pads work very well for using diesel. I have about 470 hours on my mill and probably have used about 8 or 9 gallons of fuel for lube and the blades stay clean. Since there are no belts on the wheels there is no down side. I have never smelled diesel on the lumber or in the sawdust.
Cook's AC3667t, Cat Claw sharpener, Dual tooth setter, and Band Roller, Kubota B26 TLB
Offline KWood255
« Reply #22 on: October 17, 2021, 07:18:59 AM »
I have a WM LT35, with the standard gravity fed lube tank. I would like to try diesel, but I doubt I can regulate it properly with the water jug lube system. It seems to be very inconsistent. Any recommendations on an upgrade?
Offline SawyerTed
  • Summey Lumber Services, LLC
« Reply #23 on: October 17, 2021, 07:37:49 AM »
I switched from the pvc valve to a hose bib on the lube tank outlet.  It allows better adjustments and stays set.  Once I set it to the flow rate I want a quarter of a turn shuts it off.
Woodmizer LT35HD25, WM BMS 250, WM BMT 250, Kubota MX5100, IH McCormick Farmall 140, Husqvarna 372XP, Husqvarna 455 Rancher, Ram 3500 6.7 Cummins
Offline Satamax
  • Living in Absurdistan!
« Reply #24 on: October 17, 2021, 08:07:42 AM »
Mix the three!
half pint of diesel, pint of washing up liquid, an imperial gallon of water. That's what works best for me.
Offline Durf700
« Reply #25 on: October 17, 2021, 11:35:15 AM »
I added the drip valve that I purchased from cooks on my LT 35.  works great..  just replaced the clear line from the water jug to a rubber fuel line from napa and I love it.  1 drip per second when I mill fresh cut white pine full of sap and the band stays clean..  sometimes I run it with hemlock, sometimes I cut it dry.
I just added lazer to my LT 35 also to speed up my first cut on logs with some taper and to resaw my first few cut offs that I can turn into usable lumber.  lazer is sweet!
Offline WV Sawmiller
    • Green's Sawmill Services
« Reply #26 on: October 17, 2021, 11:57:25 AM »
Durf,
  Not meaning to change the direction of this thread but the laser interests me. Do you saw indoors or out? I heard outside they are hard to see. Do you see the full length of the log or just the start? I'd be more interested in seeing where the blade will be exiting the end rather than starting which is not a big problem for me. Was it a factory/WM laser or an engineered special?
Offline Durf700
« Reply #27 on: October 17, 2021, 03:25:56 PM »
Durf,
I mill inside my building. the laser I purchased is exactly the same as what I saw on youtube channel "sawing with sandy".  he installed laser on his woodland mills sawmill about a month ago.  he has all the links in the video description.  I mounted my laser right by the sawdust shoot on my LT 35 along with the on off switch. my band wheel door can open without hitting the laser where I mounted it.  I can see the laser around half my pole barn I mill in! it should pay for its self on 1 load of logs by getting an extra board or 2 since I can now see exactly where my blade will be cutting at the far end of the log.  I can quickly raise up a toe board and know where I will end up at the far end.  the cut offs are much easier to re saw now as well and know on the 1st cut where you will be at the far end.
not sure how great they will work outside in the sun but I am very happy with my set up in my building.
Offline KenMac
« Reply #28 on: October 17, 2021, 04:35:12 PM »
Green lasers are much more visible in sunlight and are readily available also.
« Reply #29 on: October 17, 2021, 09:41:40 PM »
  Thanks for the response.
  It would take me a while to get used to sighting down that side of the mill as I have always been used to checking with the debarker and blade height on the right-hand side.
Offline Brad_bb
« Reply #30 on: October 18, 2021, 12:35:53 AM »
I use Dawn/water cutting hardwood.  What are you cutting?  Maybe Diesel works better for pine pitch?
Offline jb616
  • Hobby Sawyer
« Reply #31 on: October 18, 2021, 01:02:36 PM »
I use Simple Green for hardwood and Pine Sol for Pine. I still get a little pitch from the pine, maybe I need to up the concentrate a little?
Offline pezrock
« Reply #32 on: October 18, 2021, 09:38:03 PM »
I was using Dawn/water. Now I have the diesel dripping about 1 drip every 3 seconds. Blade is clean and everything is running great. So far I am happy. Time will tell as far as drive belt, feed hose and anything else that it makes contact with. So far, I noticed that the sawdust build-up on the blade guides is less since the switch. I am really liking it. Wish I switched earlier.
Offline Crossroads
  • letís make some sawdust
    • Kevin Bales faith family farm and portable sawmill
« Reply #33 on: October 20, 2021, 12:18:42 AM »
After 3 years, the clear hose has gotten hard, but it still functioning. I did replace my lube tank at around 1100 hours, the cap stretched and would come off the threads. Not 100% sure that had anything to do with the diesel or not, but thatís what I blamed it on.
2017 LT40 wide, Kubota l185dt, 2-036 stihl, 2001 Dodge 3500 5.9 Cummins, l8000 Ford dump truck, hr16 Terex excavator, Farmi logging winch, Valley je 2x24 edger, Gehl ctl65 skid steer
Offline Mlanier
« Reply #34 on: October 20, 2021, 06:49:47 AM »
I really think it just depends on where you are and what youíre sawing.
If youíre up north and the pitchy-est wood you saw is white pine then water and dawn will probably do you just fine.
If youíre in the Deep South and saw a bunch of SYP then youíve got to use a diesel drip.
Water and dawn, or pinesol, just wonít cut the pitch from SYP
Offline Bindian
  • Gender: Female
« Reply #35 on: October 20, 2021, 02:08:21 PM »
I saw almost entirely SYP.  I use dawn and water and when the blade sound changes from sap buildup, I open my valve and flood the blade.  When the sap disappears, the sound quiets down, then I close the valve back to drip.
Before I change blades, I open the valve up and clean the blade of sap.  Dawn and water works.  Sounds like you are not using enough.
I can't wait until I get my Lubemizer kit installed.  Then I won't have to manually adjust that darn valve again.
hugs,  Brandi
Mahindra 6520 4WD with loader/backhoe and a Caterpiller E70 Excavator.  My mill is a Woodmizer LT40HD Wide Diesel. An old Lull 644D-34 called Bull
My Hero is Johnny Jett
Offline Mlanier
« Reply #36 on: October 21, 2021, 08:24:42 PM »
Hey Brandi!
I tried every amount of water with dawn that you can think of, would just let the blade run and just dump the water on it but nothing works as well as a diesel drip.
All I need is about one drop every couple of seconds and thereís no pitch build up on the blades or guides, the saw runs so much quieter, and Iím getting more life out of my blades.
I really didnít want to put a diesel drip on my mill and talked myself out of it more times than I can count, but since I put it on Iíll never again saw pine without it.
I still use the water and dawn for hardwoods like oak or hickory, but if Iím sawing pine (which is what we saw 80% of the time) the diesel tank goes right back on the mill.
Offline Tristen
  • Location: Donovan Illinois USA, 2 hours south of Chicago
« Reply #37 on: October 25, 2021, 10:31:59 AM »
You are correct you can not regulate it properly with the standard valve from wood mizer.   you need a Sight Feed Needle Valve, Brass put it in the middle of your old water line and fill the tank with straight diesel.  I use one drip every 2-3 seconds on hard wood.  If i am sawing pine with a lot of sap i will turn it up to one drip every second.
Interest; Wood mizer LT35 HD,   Husky chainsaws, Firewood, sustainable logging, lumber, Kubota compact tractors
"You are the first person to ever see the inside of that tree"
Offline Tristen
« Reply #38 on: October 25, 2021, 10:36:59 AM »
If we are taking a vote i would vote diesel.   Everyone has already talked about how well it cleans and cools the blade, but another benefit of diesel is it makes the daily mill clean up very easy.    When i ran water there was always big globs of wet sawdust, almost like mud, every where on the roller guide, the blade belts and the sawdust shoot.  With one drop of diesel every 2 seconds there is only DRY sawdust coming off the log so the clean up is real easy.
How much water is OK in diesel?
Started by shinnlinger on General Board
Last post April 07, 2010, 07:16:08 AM
by james
Water in Diesel
Started by Corley5 on Forestry and Logging
Last post April 16, 2015, 11:27:48 PM
by barbender
Diesel made from water! Yes, really!!
Started by fishpharmer on Alternative methods and solutions
Last post December 14, 2015, 06:59:49 AM
by Randy88
water temp for diesel
Started by spencerhenry on Forestry and Logging
Last post March 21, 2008, 05:50:02 PM
by Polly
