Battery Powered Caulking Gun?
Started by Stephen1, November 17, 2021, 08:41:49 PM
Stephen1
I will putting up the log siding on the new place. I want to chink it to match my log cabin.
Has anyone had any experience with battery powered caulking guns. It will have to hold the large tubes as that is what the Chinking comes in.
sawguy21
What brand? With a good one like DeWalt or Makita you will wonder how you ever managed without it. A friend spent some serious coin on a Milwaukee grease gun, swears it is the best investment he ever made.
Stephen1
My ideal choise would be an 18volt Dewalt as that is what the rest of battery tools are.
I haven't found one on fleabee yet.
I will look or buy another type as I bet once i'm done i can sell it on fleabee.
sprucebunny
I bought a Ryobi one a couple of months ago for regular size tubes. I seem to break those manual ones pretty fast. It works great !!!
One little mishap was trying to use a tube that had been open a couple days and the plunger was working but the goop was being squeezed out the wrong end  :o That was messy but the gun lives.
Southside
Don't have a cauking gun, but I would defend my Milwaukee 18V grease gun with my life.  Put a Lock-n-Lube on the end of it, will never go back to anything else.
White Oak Meadows
newoodguy78
I don't know about the dewalt directly but know a couple framers that have other brands and swear by them. If you end up going with a manual quart gun Tajima makes the best one hands down in both the small and large tube size
Bruno of NH
All the major brands work great.
A must have if you chinking
25 years ago when I was building log homes , I used an air one made by rigid.
Was a big tube gun , worked great as well
Stephen1
I agree Bruno, I did my small log cabin years ago and wished I had a powered one then. I am trying to find one for this project and I will probably chink the inside of the cabin also.
Tom King
Since I was already well supplied with Makita batteries, that's the one I bought.  It's not for fine finish, but with your job, that's what I would use.  I do use it for some long lines of caulking for finish.
 I mainly use it for construction adhesive.  Takes longer to get a tube ready, and change it, than to empty one.
I doubt brand makes much difference.  It's a pretty simple tool.
Walnut Beast
Runningalucas
I've been considering a cordless caulk gun as well, but have a simple question.  When using a manual caulk gun, especially sporadically, you've got to release the pressure on the tube, or caulking keeps coming out due to pressure.  Do the cordless caulk guns relieve pressure on the tube between times of pulling the trigger?
Life is short, tragedy is instant, it's what we do with our time in between that matters.  Always strive to do better, to be better.
moodnacreek
Quote from: Southside on November 17, 2021, 09:18:59 PM
And 5 people agree. Why am I the odd one? A logger loaned me a battery grease gun once because I was going to buy one and I didn't. Same with lock and lube, never work for me. too many tight places. Said another way If I use this new stuff I still have to take the old gun under the machine to finish greasing.             The powered caulking gun sound like the thing, i bet you can do a neater job with it.
Iwawoodwork
the 18v powered grease gun with a standard tip or a swivle tip will get in any place that a regular hand pump gun will on my Cat D7, D3, or excavators ex50, pc60 ,  really handy when pumping/ tensioning the tracks.  As for the caulk gun I have the Royobi 18v large tube, worked fine but have not used for several years so not sure about the pressure release, but must have one.
Tom King
The Makita does pull back the pressure, to prevent excess squeeze out, when you release the trigger.  I don't know about the others.
There is a manual one that does the same thing.  I use that one for finish work in houses.  I can't remember the brand, but it's yellow and black.  Sherwin-Williams sells it in their stores.  It doesn't work the best for stiff caulking though.  I've had two different Architects tell me I was the best finish carpenter they'd ever seen.  What they didn't see was that I was the best caulker they'd ever seen.
I have a whole bunch of grease guns with various tips, hoses, angled ends, etc., as well as different ones for different greases.  I couldn't get by with just a couple.
Bruno of NH
I believe all the battery operated ones pull back when the trigger is released.
I agree with Tom about using it for things like construction adhesive.
I also agree with newwoodguy about the hand tajima brand best on the market
sprucebunny
Yes, my cordless gun releases the pressure and though it's nessasary, it's a little irritating because you don't know when it will start coming out and it sometimes leaves the inside of the tube exposed to air.
Love my Milwaulkee grease gun. Besides the Lock N' Lube, I have a lock on right angle thing that was absolutely needed for one fitting on my old F350. (1990 no rust, no winters)
Southside
Quote from: moodnacreek on November 18, 2021, 01:14:50 PM
I had a different battery powered grease gun before the Milwaukee, night and day difference. I also have a 3" pointed extension that the Lock n Lube accepts for tight spots and a 90 that just threads on for the impossible otherwise spots.
No more holding the hose onto the zero with one hand, squeezing the handle of the gun against my chest with the other, and holding onto whatever piece of equipment I am standing on 7' in the air with my third hand.
White Oak Meadows
Stephen1
I have been searchiing for a new 18V dewalt but no luck. They are all out of stock and all I find are the 20V.
if I am going to move to a newer tool/battery I really like the Milwaukie brand.
I am going to set up some searchs on Flea Bay Kijiji and see what comes along. I will not be chinking untill the spring so I have a bit of time.
Southside
I have picked up most of my set from CPO Outlet. They have good deals on factory reconditioned units with full warranty.
White Oak Meadows
Tom King
I've gotten some factory reconditioned tools from CPO that only looked like the box had been opened.  The cords even still had the twist ties still on them.
Southside
I recently bought a factory reconditioned, super sized, weed whacker that goes behind an ATV to trim fence rows.  Was looking it over trying to see what might have been done to it and swore it had never been run, then I found it.  Someone had put a decal across the rear of the machine that was intended for the 3 point hitch PTO driven model, not the self powered, trailerd one.  Brand new, full warranty, saved several Benjamins $$ because of a sticker.  Fine by me.
White Oak Meadows
moosehunter
I have the 20 volt DeWalt caulk gun. Nice tool.
mh
Higher than my expectations
Stephen1
Quote from: moosehunter on November 19, 2021, 09:13:26 AM
mh
Thanks MH I might have to upgrade to the 20 volt if I can't find an old 18 around somewhere.
Corley5
  I was wishing I had a Milwaukee 18v caulk gun in my collection yesterday.  I seldom have a need for such a tool but had to replace the door glass in my front end loader yesterday.  The 3M Window Weld came out of the tube hard :).  The cheapo hand gun I had wasn't real efficient let alone convenient ;) :)
  I liked my Lincoln 14.4 grease guns but really prefer my Milwaukee 18v.  The Lincolns went to auction earlier in the fall ;D
Southside
Lincoln 14.4 - that's what I had before my Miluakee.  Was so upset to replace it that I forgot who had made it.   :D
White Oak Meadows
