Author Topic: Concrete base for sawmill  (Read 8420 times)
Online doc henderson
Re: Concrete base for sawmill
« Reply #40 on: September 18, 2021, 07:15:26 AM »
it is always dangerous asking for advice with things like pouring concrete.  even my buddy Eddie who has done it for 40 years, will waffle on certain "rules" for no apparent reason.  so the piers could be a mixed blessing.  can transmit forces on the pad down to solid ground below the frost line, and make everything more solid.  If the whole pas settles, the concrete may crack there.  If you have a 3,000 pound log on a 1,000 pound mill, that is 2 tons, and divided that into the square inches of surface on the pad.  many jack have what seems to be a 2 x 4 inch foot (prob. more)  if there are 6 of these jacks supporting the mill, then 6 x 8 is all the weight on 48 sq. inches or 83 pounds per sq. inch.  you could also put a chunk of wood under each jack say 12 x 12 and now you spread out the forces and reduce to 4.6 pounds per sq. inch.  if you will be dropping and scooting large logs, this will impart some dynamic forces as well in addition to the static force.  you have all kinds of options.  you can form a slab that is 4 inches in the interior, with a 6 inch thick edge for a foot reinforced with rebar like a beam or mass footing.  a simple 4 inch slab with some wire roll mesh in it is much better than what you currently have.  I have what you have at this point.  If you have well compacted soil, you can dig the holes for the footings, and pour it all in one pour.  it is only time and money. ;) :)
« Reply #41 on: September 18, 2021, 07:20:12 AM »
On the tires, unless they are suspended off the ground, then they are sharing part of the weight.  my jacks and tires are all in line,  I am liking the thicker edge with rebar along the edge better and better,  I think that is what I would do.
Offline 2308500
« Reply #42 on: September 18, 2021, 10:01:39 PM »
4 piers dug down 3 feet below grade  and 6 inch pad with rebar and wire mesh. overkill.....maybe...maybe not
Online thecfarm
« Reply #43 on: September 19, 2021, 05:23:59 AM »
overkill? you will never know.  ;)
overkill has made me feel better about a build many times.  ;D
Offline kelLOGg
« Reply #44 on: October 24, 2021, 07:12:38 AM »
It is finally done. 4 x 27 with 2 x 4 for the tires and 4" thick. Packed gravel beneath all - but no rebar. My concrete guy said it wasn't necessary. Hope he's right. Good bunch of guys to watch work. I told them it was the first time I had watched people work. While it cures I will be getting my 1st cataract surgery.
Offline Bindian
  • Gender: Female
« Reply #45 on: October 24, 2021, 02:28:24 PM »
No rebar?  I think your concrete guy is wrong.  Guess you won't be handling any huge logs.  I do hope I am wrong.
hugs,  Brandi
Mahindra 6520 4WD with loader/backhoe and a Caterpiller E70 Excavator.  My mill is a Woodmizer LT40HD Wide Diesel. An old Lull 644D-34 called Bull
My Hero is Johnny Jett
Offline kelLOGg
« Reply #46 on: October 24, 2021, 03:47:19 PM »
32" dia is the max. Usually less than 16'. Fingers crossed. I guess what I failed to emphasize to him is that logs "fall" several inches when they are turned.
Offline 230Dforme
« Reply #47 on: October 24, 2021, 04:14:24 PM »
They didnt want to unload, carry, cut
or tie the rebar
« Reply #48 on: October 24, 2021, 04:22:51 PM »
no option now but to wait and see.  I only use the plastic fiber when nothing else will work.  keep us in the loop!  thanks.  I used it in my pool floor under vinyl and in the 1.5 inch slab over plywood and trusses in my shop with floor heat, and it has done well.
I would put some relief cuts as it is long and skinny and will crack, even if you had put mesh and rebar in it.
Offline Bindian
  • Gender: Female
« Reply #49 on: October 24, 2021, 11:53:20 PM »
Oh, okay.  Not too big.   When I load a huge 36 incher 20 feet 3 inches with the loader arms, if it rolls too fast on the bunks to the back stops, my whole mill moves, then settles back down with a thunk.  Think water shifting back and forth in a dog's water bowl.
All bets are off if you accidently drop a log while sitting it down on the bunks.
hugs,  Brandi
Offline kelLOGg
« Reply #50 on: October 25, 2021, 05:42:30 AM »
I roll logs onto the mill over ramps from the rollway. The only "thunk" I get is when rotating to a new face.
Offline bannerd
  • Madman
« Reply #51 on: October 25, 2021, 07:07:21 AM »
Something that works pretty well is a ruble trench.  Have a backhoe come in and dig below the frost lines and then fill it with number 2 stone or number 1 stone.  Make sure he or she runs a drainage pipe at the bottom as the cold water/ice will absorb thermal the deeper it creeps.  It needs to run out at some point.  Compact it (not much to compact with stone) and when that is done, pour the concrete slab on top of that.
Bandsaw sawmill build - the base
Started by DMcCoy on Sawmills and Milling
Last post February 08, 2015, 03:06:55 PM
by valley ranch
Concrete sawmill pad --- 14 x 4 x 6" --- what not to do
Started by OffGrid973 on Sawmills and Milling
Last post June 15, 2017, 06:43:44 PM
by ChugiakTinkerer
concrete floor for sawmill
Started by AvlSteve on Sawmills and Milling
Last post October 07, 2021, 09:33:55 PM
by Larry
DIY base, do i buy?
Started by Satamax on Sawmills and Milling
Last post August 24, 2011, 10:03:09 PM
by shelbycharger400
