Author Topic: Free Walnut Logs,  (Read 1474 times)
Offline 123maxbars
    • www.outofthewoodsforestry.com
Free Walnut Logs,
« on: July 19, 2011, 10:38:42 AM »
Just a quick question for you guys, i don town a mill (yet) but my co worker has the LT28 and I work with him on small jobs, though he is new to milling also and is like me trying to gain knowledge. I had a guy give me three walnut lots this morning that were cut six weeks ago. They were not sealed when they were cut, are logs like this that have been cut for a while that where not sealed good candidates for milling? Thanks for any help.
Sawyer/Woodworker/Timber Harvester
Woodmizer LT Super 70 Wide, Nyle L53 and 200 kiln, too many other machines to list.
outofthewoods
Youtube page
Out of the
Offline dutchman
  • Sawyer SW PA TimberHarvester 30HT
Re: Free Walnut Logs,
« Reply #1 on: July 19, 2011, 11:17:04 AM »
End sealing keeps the end of the log from drying faster and checking (cracking).
The lumber from the log will still be fine. You may lose some length.
Offline Jeff
  • Fearless Leader
  • Oh la di oh la da
    • Behind the  Forestry Forum YouTube channel
« Reply #2 on: July 19, 2011, 11:18:07 AM »
Certainly.
The mill I sawed at never sealed any logs. We did try to saw our grade logs up asap and keep them in the shadier locations in the mill yard, or at least piled where they would shade each other, but we never sealed a log there in 25 years that I was there.
Offline terrifictimbersllc
    • Terrific Timbers LLC
« Reply #3 on: July 19, 2011, 01:23:50 PM »
Good advice above already.  Walnut logs last a long time, especially if laying on the ground or otherwise kept as wet as possible.  6 weeks is nothing, except for whatever cracking on the ends has already occurred.  Sealing slows this but only where cracks haven't already started.  To do your best, trim off a little to eliminate the small cracks and seal them.  Keep them in the shade. After sawing, seal the ends in a couple of inches. If you sawed without sealing you can just trim each board and seal once then.
Offline Planman1954
« Reply #4 on: July 19, 2011, 04:13:58 PM »
Six Weeks?? Naww..they're not any good NOW...I'll be over later to haul them off for ya... :D
Norwood Lumbermate 2000 / Solar Dry Kiln /1943 Ford 9n tractor
Free walnut logs
Started by oakiemac on Forestry and Logging
Last post June 23, 2004, 08:28:21 PM
by oakiemac
Free Firewood logs id - potentially black walnut?
Started by cadyfatcat on Tree, Plant and Wood I.D.
Last post June 07, 2019, 09:28:06 PM
by caveman
Free logs sometimes aren't really free
Started by WoodenHead on Sawmills and Milling
Last post September 26, 2012, 04:07:14 PM
by tyb525
FREE WALNUT
Started by stanwelch on Sawmills and Milling
Last post March 28, 2014, 07:07:11 PM
by ET
