Author Topic: Lubemizer leaking  (Read 342 times)
Offline Dan_Shade
  • I don't want to edit my profile!
    • Shade Custom Sawing
Lubemizer leaking
« on: January 08, 2020, 07:58:14 PM »
I'm assuming that I have a bad check valve in the lubemizer tubing, because it constantly flows.
I'm not sure how it is supposed to be plumbed up with the check valve direction.
Does anyone have a diagram?
lots of dull bands and chains
Offline PAmizerman
    • Byrne Millwork
Re: Lubemizer leaking
« Reply #1 on: January 08, 2020, 08:26:33 PM »
I replaced the check valves in mine. I don't recall the direction but I'll try and remember to look tomorrow if I get time.
Hydraulics everywhere
Traverse 6035 telehandler
Case 95xt skidloader
http://byrnemillwork.com/
WM bms250 sharpener
WM bmt250 setter
Offline PAmizerman
    • Byrne Millwork
« Reply #2 on: January 08, 2020, 08:27:47 PM »
There should be an arrow on them which is the direction of flow.
WM bms250 sharpener
WM bmt250 setter
Offline Dan_Shade
« Reply #3 on: January 08, 2020, 09:38:05 PM »
I'll just order both check valves
One of mine had a sticker showing direction, but it fell off.
I guess the loop is to keep the pump from deadheading.
Lubemizer
Started by petefrom bearswamp on Sawmills and Milling
Last post December 06, 2012, 06:39:32 PM
by POSTON WIDEHEAD
Lubemizer Issues
Started by jcbrotz on Sawmills and Milling
Last post July 29, 2011, 01:54:03 PM
by Magicman
Protecting your LubeMizer, etc.
Started by Magicman on Sawmills and Milling
Last post February 04, 2010, 06:23:51 AM
by DR_Buck
Lubemizer worth it?
Started by moandrich on Wood-Mizer
Last post January 19, 2022, 12:58:04 PM
by terrifictimbersllc
