Is this the twin wall stuff you were talking about? If so, when it says 49.5 inches, is that the vertical, and then the width is 99"?(Image hidden from quote, click to view.)
Well I'm interested to see how the panels are installed. I read the instructions:https://www.greenhousemegastore.com/content/files/pdf/Multi_Install.pdfI understand the point fastening, but am not clear about joining panels together, and how the panels join at the sides and bottoms of kiln so water doesn't get in.@etd66ss are you using the 8mm twin wall panels?https://www.greenhousemegastore.com/coverings/plastic-sheets/polycarbonate-sheets/easy-ship-2-ft-wide-twinwall-polycarbonate?returnurl=%2fcoverings%2fplastic-sheets%2fpolycarbonate-sheets%2f
Good progress. Thanks for the update. I painted the outside dark green. Absorbs heat pretty well but more attractive than black.
does that green have a specific name, it is very classy with the black trim.
Any update on the build @etd66ss ?
Started by caveman on Drying and Processing
Started by Wes06 on Drying and Processing
Started by relicshunter on Drying and Processing
Started by GF on Drying and Processing
