Removing the sawdust will be a real pain without that concrete pad if you are on gravel. The tarp is a temp solution at best. Sawdust is heavy and you will have the opportunity to deal with many torn tarps .
Started by paul case on Sawmills and Milling
Started by petefrom bearswamp on Sawmills and Milling
Started by shinnlinger on General Board
Started by losttheplot on Timber Framing/Log construction
