FIRE DOOR GASKET
Started by jerry sundberg, October 23, 2021, 07:05:18 AM
jerry sundberg
Where can I get a casket for the door on my Heatmor 100 boiler?
Farmall  man
Corley5
Is it rope gasket?  I got gasket for my syrup evaporator and OWB off Amazon after a Google search.
petefrom bearswamp
I see rope gasket material kits in my local TSC store in various diameters and lengths.
My OWB is from 2005 and I have never changed the gasket with no perception of loss of  performance.
Kubota 900 RTV
Polaris 570 Sportsman ATV
57 acres of woodland
barbender
I got rope gasket and the silicon rubber seal maker at the local farm and fleet store. BTW, a leaking door gasket will cause massive creosote buildup and plug up your chimney.
kantuckid
So many places it's a tough answer. Some sell bulk off the roll by the ft, others sell brand/model kits, on & on & on...
A link that will help.
replace heatmor gasket
Any hardware store should have it.
GRANITEstateMP
I get mine from the local hardware store. They are getting harder to find.  I buy it by the foot and get enough to do it twice. Don't forget the glue!
Hakki Pilke 1x37
Kubota M6040
Load Trail 12ft Dump Trailer
2015 GMC 3500HD SRW
2016 Polaris 450HO
2016 Polaris 570
SureTrac 12ft Dump Trailer
mrcaptainbob
Can that rope seal be replaced while the stove's in use? If I let it die down to just coals....quick clean the  door surface, set the silicone and rope and close the door?
barbender
The silicone has to sit a while to cure is the problem.
trapper
barbender
I let mine cure for a day, I don't remember what the actual recommended time was. It just has to set, so you don't glue your door shut😁
Al_Smith
I've glued them back in using sodium silicate paste which is used for repairs on mufflers .Glue it back in ,shut the door and just run the heater as you usually do .
jaygtree
l&m fleet in ashland has bulk gasket rope and adhesive. fleet farm in duluth mite have bulk gasket too. jg
i thought i was wrong once but i wasn't.   atv, log arch, chainsaw and ez boardwalk jr.
