Author Topic: How to start an argument, friendly one, but arguement just the same..:)  (Read 830 times)
Offline weimedog
  • Better to be a "Has Been" than a "Never Been"!
As the years have gone by I like many others fold into then out of the fads defined by our peers online. Since this saw thing is as much a hobby as anything, things that make it more interesting and reasons to celebrate within the community are the focus. Saw Mods and GTG's derived from motorsports & racing are an out growth of that. A way to both enhance and interact all wrapped up in one. I certainly have enjoyed all of that from modding saws to the informal races and comraderies developed as a result over time. THEN time passes. The work load increases if any thing....and the saw thing divides into to classes of thought....task oriented, fun oriented. Priorities shift. And I decided to do a self reflection a while back and move back to the farm and task oriented thought process. AND from that perspective did a comparison between my "new 4 me" this year 565 and my favorite 372 based saws, an OPINION developed after a Spring & Summer's Use....It's all Vic C's and Bob's fault.
( This fall getting back to "fun" with my Oldie but Goldie's, Husqvarna L65/77's and Jonsereds with a Homie xl925 build to happen )
Husqvarna 365sp/372xpw Blend, Jonsered 2171 51.4mm XPW build,562xp HTSS, 560 HTSS, 272XP, 61/272XP, 555, 257, 242, 238, Homelite S-XL 925, XP-1020A, Super XL (Dad's saw); Jonsered 2094, Three 920's, CS-2172, Solo 603; 3 Huztl MS660's (2 54mm and 1 56mm)
Offline Tacotodd
  • To learn and help
Re: How to start an argument, friendly one, but arguement just the same..:)
« Reply #1 on: November 04, 2021, 09:11:07 PM »
Well, I hope that you have fun with your saws. It’s gonna be a wild ride, but aren’t they all ? !
Trying harder everyday.
Offline WV Sawmiller
    • Green's Sawmill Services
« Reply #2 on: November 05, 2021, 08:39:18 AM »
  I don't seem to have start talking about chainsaws to start and argument. All I have to do is post any little, entirely honest (but generally correct) comment about women and the gentler sex here on the FF take it from there. :D
  Good luck on your saw project.
Offline Tacotodd
  • To learn and help
« Reply #3 on: November 05, 2021, 05:25:24 PM »
Offline HemlockKing
« Reply #4 on: November 05, 2021, 06:36:00 PM »
   Good luck on you saw project.
Always batting the beehive lol
“A society that puts equality before freedom will get neither. A society that puts freedom before equality will get a high degree of both.“
Milton Friedman
Offline YellowHammer
  • Sawing is fun for the first couple million boards.
    • Hobby Hardwood Alabama
« Reply #5 on: November 05, 2021, 06:43:55 PM »
And you’re an Auburn fan.  That would start an argument in a commune full of pot smoking, Dorito munching, beatniks.
I like the saying, “two schools of thought, task oriented or fun oriented.”  I hadn’t heard that one before.
YellowHammerisms:
Take steps to save steps.
If it won’t roll, its not a log; it’s still a tree.  Sawmills cut logs, trees.
Kiln drying wood: When the cookies are burned, they’re burned, and you can’t fix them.  So don’t burn the cookies.
Sawing is fun for the first couple hundred boards.
Offline David B
  • davidwyby
    • Yahoo! Photo album.
« Reply #6 on: November 06, 2021, 07:16:39 PM »
Watching the vid reminded me I did a comparo experiment a while back. Two big pine spars about 40” at the base. I felled one with the 3120 42” and one with the Dolmar 6100 24”. Not surprisingly, the big saw was a lot to swing around but easier to line up the cuts and no monkeying around. The 6100 is a lot easier to maneuver but you gotta do it a lot and be good at lining up cuts.
When it came time to buck into firewood it was the same thing…I prefer the bigger saw and bar for that. If I was ever to be felling a lot I suppose I would run a bar a bit on the long side, just enough power for it, and maybe skip chain.
For those two trees for example, ported 2166 with a 36” bar would probably have been ideal, or the 395, but they were at Kevin Lavanway’s getting more horsetorques installed.
SE Calif. 2139, 2050, 2252, 49SP, 2159, 2166, 6100, 395xp, 3120...and a few projects....
Offline Woodfarmer
« Reply #7 on: November 07, 2021, 01:03:59 PM »
I bought a 565 to try but just didn’t find it too exciting. So I sold it.
Prefer the 2165/71’s. Since Husqvarna mothballed Jonsered I’ve been buying Stihl. It will be a long tim before I buy an oranges saw, unless it’s an echo!
Offline David B
  • davidwyby
« Reply #8 on: November 08, 2021, 10:38:50 PM »
I’m gonna try a makita 7900…monster in this weight class.
being friendly
Started by luvmexfood on General Board
Last post May 21, 2017, 08:50:01 AM
by thecfarm
A Little Friendly Competition
Started by Norm on FOOD! FOOD! FOOD!
Last post June 15, 2010, 08:27:17 AM
by Raider Bill
Friendly Sawyers
Started by macurtis on Sawmills and Milling
Last post March 22, 2002, 05:16:29 AM
by ARKANSAWYER
friendly people
Started by bedway on Sawmills and Milling
Last post August 11, 2006, 01:23:43 AM
by Homer
