Author Topic: Maspell vacuum, heat and pressure kiln?  (Read 730 times)
Offline Satamax
  • Living in Absurdistan!
« on: April 13, 2022, 06:14:37 AM »
Hi everybody.
Well, i have friends taking the plunge. They have a kiln from Maspell. Which goes to auction on the 27th of April.
It's a heat and vacuum one. Heated aluminium plates top and bottom, the top is a heavy rubber membrane, which exerts pressure on the top plate with the vacuum, in turn compressing the wood too.
Vacuum pump seems to pith oil, or sap may be. Feels greassy to the touch.
I'm just wondering if i fight for it? Or let it go to the two other persons which are interested by it. Or some other, who'll turn up for sure.
It's i think a maspell M3 1.6 (1.6 cubic meter, or 424 bdft)
If ever someone knows that one? I can't seem to find any technical information about it.
Offline customsawyer
    • The Custom Sawyer
Re: Maspell vacuum, heat and pressure kiln?
« Reply #1 on: April 13, 2022, 06:46:08 PM »
Are your friends that are selling it still in the business? If they are than I wouldn't buy it. If they are getting out completely than I would look at it harder if it fit my business. I would have zero use for a 400 bf kiln but that is just me.
Two LT70s, Nyle L200 kiln, 4 head planer, 30" double surface planer, Lucas dedicated slabber, Slabmizer, and enough rolling stock and chainsaws to keep it all running.
www.thecustomsawyer.com
Offline Satamax
« Reply #2 on: April 14, 2022, 06:55:49 AM »
Hi Customsawyer.
Jean Marc, the father, retired last year or the year before.  And Alex the son,  has recovered from a  cancer, at thirty something.  And has "burned out" In december.  They're closing and selling everything.  But it goes through some legal actions and an auctioneer. As they had to default some payments.
Offline YellowHammer
  • Sawing is fun for the first couple million boards.
    • Hobby Hardwood Alabama
« Reply #3 on: April 14, 2022, 07:39:17 AM »
It would depend upon strategy and goals.  For such a small unit, I would think it would be about right for drying high value wood thick slabs fairly quickly, maybe a couple logs worth at a time, if it would handle the physical size of larger pieces.
I'd use it as a specialty unit for specialty wood if I could get it at the right price.
YellowHammerisms:
Take steps to save steps.
If it won’t roll, its not a log; it’s still a tree.  Sawmills cut logs, not trees.
Kiln drying wood: When the cookies are burned, they’re burned, and you can’t fix them.  So don’t burn the cookies.
Sawing is fun for the first couple hundred boards.
Offline Satamax
« Reply #4 on: November 26, 2022, 07:38:42 AM »
Updates guys. A friend of mine has  bought it. His workshop is 100 yards from me.
    • The Custom Sawyer
« Reply #5 on: November 26, 2022, 06:07:52 PM »
Good deal. Maybe you can hire him to do some drying for you.
Offline Satamax
« Reply #6 on: November 26, 2022, 10:59:07 PM »
Yep, me cutting for him, and him drying for me. That will happen, i guess.
moved
MOVED: Maspell vacuum, heat and pressure kiln?
Started by chet on Sawmills and Milling
Last post April 14, 2022, 07:55:49 AM
by chet
recirculating water for a vacuum kiln vacuum pump
Started by schwanee on Drying and Processing
Last post December 15, 2020, 02:47:00 PM
by schwanee
Vacuum & pressure tests
Started by johnny newburgh on Chainsaws
Last post December 20, 2017, 09:48:46 AM
by weimedog
Vacuum Kiln
Started by J_T on Sawmills and Milling
Last post March 04, 2002, 07:57:11 PM
by woodman
