Author Topic: L200M question regarding the auto override temp switch  (Read 416 times)
Offline jimbarry
  • Work less, make more.
    • Woodchuck Canuck
« on: November 23, 2022, 02:20:42 PM »
Loaded two cord today.
It will take two days running electric to get the heat up to about 120ºF where it will remain somewhat stable. I was thinking about supplementing the heating with propane to bring up the core temp of the firewood quicker.
If I use the propane and the air being blown around gets over the compressor's temperature safety limit, let's say 160º or so, will anything happen to the compressor? The switch that shuts off the compressor when it gets too hot, does that only function if the compressor is on?
Offline K-Guy
    • http://www.nyle.com/
Re: L200M question regarding the auto override temp switch
« Reply #1 on: November 23, 2022, 03:35:10 PM »
It's a pressure switch, so the compressor has to be running.
Nyle Service Dept.
- D. Adams
Offline jimbarry
    • Woodchuck Canuck
« Reply #2 on: November 23, 2022, 04:29:00 PM »
Thanks Stan.
Online doc henderson
« Reply #3 on: November 23, 2022, 04:47:59 PM »
direct fire propane heat will add some water/humidity to the kiln, but overall should lower RH.  at the end of the heat cycle, consider opening up to vent humidity if the water content is more than the DH can pump out.
Offline jimbarry
    • Woodchuck Canuck
« Reply #4 on: November 23, 2022, 07:04:48 PM »
Doc, its been my experience that all we have to do is load and let it go until the avg MC is 20%. One thing I did learn is that once the thermal mass of the kiln's contents is up near 120ºF (generally 1-2 days of heating), I can shut off the heater and just let the heat generated by the fans and compressor itself get the temp around 115-120ºF. Which is plenty enough to keep the drain line dripping steadily. This time of year its taking 4-5 days to bring a load down to 20%. The cost incurred on each cycle is reasonable. I only wish now that we can do it quicker to keep up with demand. We now thinking about a 6-8 cord unit either propane fired of wood fired.
« Reply #5 on: November 24, 2022, 07:33:05 AM »
I think the key is a flue for gas fired heaters if you want dry air.  The net gain is prob worth it.  I was just throwing ut that a propane heater that vents to the space is also adding some water to the kiln.  the net EMC may be lower than without heat.  the DH will have some extra work.  Ideally the burned gas is exhausted to the atmosphere.
« Reply #6 on: November 24, 2022, 07:39:30 AM »
I have thought of using an old gas furnace or a wood fired forced air furnace.  could you preheat the wood in a separate insulated building then move to the DH kiln?  The unknown for me is the cost vs production.  efficiency.
Online Don P
    • Calculator Index
« Reply #7 on: November 24, 2022, 07:45:01 AM »
That kind of describes a predryer
The future is a foreign country, they will do things differently there - Simon Winchester
Offline jimbarry
    • Woodchuck Canuck
« Reply #8 on: November 24, 2022, 08:31:04 AM »
A cost it would be. We don't have another insulated bldg.  Wood fired forced air seems to be the method. Less cost, more work.  The universe it seems always finds a way to balance the scales.
Offline K-Guy
« Reply #9 on: November 25, 2022, 08:35:46 PM »
Jom
Be aware most heating appliances in North America have thermal overload that will cut the out at 104 F.
Nyle Service Dept.
- D. Adams
clip
Nyle L200M, heating question once you reach 120º
Started by jimbarry on Drying and Processing
Last post March 08, 2020, 03:48:07 PM
by jimbarry
question
Drum Switch Service Question
Started by SawyerTed on Sawmills and Milling
Last post April 22, 2018, 12:34:14 PM
by SawyerTed
Jonsered 2172 on off switch question
Started by bt2172 on Chainsaws
Last post November 23, 2015, 11:40:31 AM
by dougand3
Temp Question on EC-2400
Started by Bob Lentz on Firewood and Wood Heating
Last post February 03, 2012, 04:46:11 PM
by wayno12
