Thank you for your answers. I'll reconfigure the motors and post back how it went.
the circuit board/ electro panel of the machine has his own small transformer to make lower voltage electricity for the commands
. . . auction in Lethbridge . . I'll post an update . . and bidding at Ritchie's.
Once you reconnect you motor leads- ideally you will want to replace the overload/heaters on the contactors so you will have proper over load protection, since your cutting the amps in have the existing overloads won’t protect the motors. They might have a dial where you can adjust but typically that’s out of the adjustment range. And as all ready stated, the transformer for your control circuits will need to have the taps reconnected. I’m pretty sure scmi smaller moulder share a motor for the vertical spindles.
Started by tacks Y on Sawmills and Milling
Started by Stormo on Drying and Processing
Started by MBRO on General Woodworking
Started by LA Horn on General Board
