Nyle L200
Started by Jmike, November 25, 2022, 09:47:41 AM
Jmike
Regarding the Nyle L200
The way I understand it when reach the "end of cycle" the MC setting has been reached.
To set the pitch you set the temp to 150F for 24 hours. How do you get the controller to stay on
for 24 more hours if the MC has reached the setting?
Thank you
K-Guy
To st the pitch, turn the compressor off, set the dry bulb to 160, and set the final moisture to zero. Otherwise the probes will turn the heat off and the screen will show end of cycle.
Nyle Service Dept.
- D. Adams
Jmike
"Set moisture to zero"
Thank you, I guess I should have thought of that.
Rick Fisher
Does the Nyle 200 reach 150 degrees or 160 degrees or do you need the heat booster with it ?
K-Guy
If your kiln is tight and well insulated, it can reach 160°F but it may take a while, the heat booster speeds the pre-heat up and heat treat up.
Nyle Service Dept.
- D. Adams
