Author Topic: Question on stacking lumber for drying  (Read 804 times)
Offline D6c
« on: November 26, 2022, 12:05:41 PM »
My questing is, as you sticker your lumber and have some bowed boards, do you have a preference on which side up you lay them?
I've been putting them all with the bow up (high in the middle), thinking they would be more likely to flatten that way as opposed to having the ends up.
Any thoughts on whether it makes a difference, or do you even pay attention to how they lay?
Offline Jim_Rogers
  • Keep your chisels sharp.
    • jrsawmill.com
Re: Question on stacking lumber for drying
« Reply #1 on: November 26, 2022, 12:28:02 PM »
I believe the kiln drier's handbook says to stack lumber center of the tree up.
But I could be wrong.
Jim Rogers
Online beenthere
« Reply #2 on: November 26, 2022, 01:54:08 PM »
Assume not talking about cup here.
If bow, think D6c has the right approach. In the end, the weight of the pile above the bowed boards will be the key, and praying it will straighten the bow out of the boards might help too.  ;)
Online YellowHammer
  • Sawing is fun for the first couple million boards.
    • Hobby Hardwood Alabama
« Reply #3 on: November 26, 2022, 06:13:28 PM »
I stack mine "opposite spoon" (I don't know what to call it) but the bow of each layer is stacked opposite to limit "sympathetic spooning" or "Pringleing" like the potato chips.  So I stack my layers like ()()() as opposed to (((((( or ))))).   Then put lots of weight on them, either other packs of wood or concrete or something.  Press them flat like pressing a flower in a book.  Make sure your stickers are lined up neatly or you will get "kinking" or "zig zag" which is almost impossible to plane out.  Sorry for all the technical terms.  :D :D :D
YellowHammerisms:
Take steps to save steps.
If it won’t roll, its not a log; it’s still a tree.  Sawmills cut logs, not trees.
Kiln drying wood: When the cookies are burned, they’re burned, and you can’t fix them.  So don’t burn the cookies.
Sawing is fun for the first couple hundred boards.
Offline Larry
« Reply #4 on: November 26, 2022, 09:57:27 PM »
Leave it to YH, we have a new term...."opposite spoon". :D :D  I expect a youtube on this method. :)
I do the same way, but I called it stacking bananas.  I do try to position the bananas.  After I get two flat layers I'll put on bananas and try to keep them in the bottom third of the stack so they have plenty of weight on them.
Offline D6c
« Reply #5 on: November 27, 2022, 09:28:18 AM »
That's what I was wondering about but couldn't think of the right terminology.
I began thinking about it ⅔ through a stack and wondered if I was creating "sympathetic spooning" as you call it.
Online YellowHammer
« Reply #6 on: November 27, 2022, 09:35:43 AM »
I have found that out makes a noticeable difference when stacking green wood, the greener the better.  As it dries out it becomes less effective.
I noticed that when I would stack lots or wood with the same bow shape, like Pringles, the stressed boards would overpower the neutral boards and cause them to Pringle to the same shape.  So this puts flattening loads on the bowed boards but also protects the neutral and straight boards.
It makes a very significant difference when air drying thick 8/4 wood, especially slabs.
YellowHammerisms:
Online Patrick NC
  • I'm not new anymore, but still pretty green
« Reply #7 on: November 28, 2022, 08:26:51 PM »
Up until now I haven't stacked any lumber for drying. Sold everything green.  My plan has changed somewhat now so this is great information for a newbie like me.
Norwood HD36, Husky 372xp xtorq, 550xp mk2 , 460 rancher, Kubota l2501, Case 1845 skid steer,
Offline Canadiana
  • I was new a while ago
« Reply #8 on: December 04, 2022, 03:03:54 PM »
If it's important for them to be straight, I use dunnage and wratchet strap them snug. If it's not done this way they're never straighter later but usually I can just live with a little twist
The saw is more fun than the purpose of the wood... the forest is trembling 🌳
Offline Ianab
« Reply #9 on: December 04, 2022, 11:59:10 PM »
This.
You have some chance of persuading a bowed green board to stay flat as it dries. It might still have some "spring" and not be prefect. But once a board is dried in a bow (whether it had one to start with or not), it will want to spring back into that shape for ever. Same as poor stacking can create a bow, and once it's set in place, it's there for good.
Online jpassardi
  • Converting Tree Carcasses 🌲
« Reply #10 on: December 14, 2022, 01:11:34 PM »
This is a positive property of wood if you're making wagon wheels, straight lumber - not so much...
LT15 W/Trailer
Husky 372XP, 550XPG, 60, 50
Bobcat 763, Kubota RTV 900
Orlan EKO Wood Gasification Boiler
Proper stacking and drying of lumber outdoors.
Started by Aeneas61 on Drying and Processing
Last post February 19, 2016, 06:08:56 AM
by Peter Drouin
Lumber Stacking Question
Started by pinehillstacker on Sawmills and Milling
Last post January 15, 2012, 07:49:05 PM
by Tree Feller
Question re: air drying lumber
Started by joegeds on Drying and Processing
Last post December 10, 2016, 07:29:24 AM
by GeneWengert-WoodDoc
question on drying green lumber in Nyle 8/4
Started by Kelvin on Drying and Processing
Last post March 03, 2009, 08:43:17 AM
by Kelvin
