Author Topic: Interesting fix  (Read 776 times)
Offline donbj
Interesting fix
« on: January 19, 2023, 01:38:38 AM »
Picked up this 380CD. These have the plastic handle that kinda is missing on this one :D  This fellow created this fix to keep it going. The center piece with the black piece on it slides back and forth under the straps that hold it in. It’s connected to the throttle control rod and it works like a darn! The saw runs fine. I have the proper handle to put things right. I think this is pretty cool!
I may be skinny but I'm a Husky guy
Woodmizer LT40HDG24. John Deere 5300 4WD with Loader/Forks. Husky 262xp. Jonsered 2065, Husky 65, Husky 44, Husky 181XP, Husky 2100CD, Husky 185CD
Offline Spike60
Re: Interesting fix
« Reply #1 on: January 19, 2023, 07:29:28 AM »
Guess ya gotta plan on wearing gloves when you run that girl.  :)
Had my 280 out yesterday. Nearly identical to yours. 480 looked quite different. All those saws used the same top end. Starting with the L77.
Husqvarna-Jonsered
Ashokan Turf and Timber
845-657-6395
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
Re: Interesting fix
« Reply #2 on: January 19, 2023, 08:37:36 AM »
Without Duct Tape, that would never work anyway.  ;D
Offline SnoJetter
  • Gramps was a logger and he taught me well!
Re: Interesting fix
« Reply #3 on: January 19, 2023, 08:49:33 AM »
A guy should preserve that just to capture the history of one interesting shade tree repair.  Maybe a guy could install it on an empty case and hang it on the wall for display.
Offline PoginyHill
  • Gentleman logger
Re: Interesting fix
« Reply #4 on: January 19, 2023, 09:40:14 AM »
Your 3D printer not working?  :D
Kubota M7060 & B2401, Metavic log trailer, Cat E70B, Case 310, 750 Grizzly ATV, Wallenstein FX110, 84" Landpride rotary hog, Classic Edge 750, Stihl 170, 261, 391
Offline DHansen
  • I'm still learning!
Re: Interesting fix
« Reply #5 on: January 19, 2023, 10:04:40 AM »
Local glove sales would increase.
Offline donbj
Re: Interesting fix
« Reply #6 on: January 19, 2023, 12:10:23 PM »
Gloves for sure! The guy rolled a log onto the handle when cutting firewood. He jimmied it together to finish his wood. Following year he bought a new saw.
Here's a couple 480's beside the 380. Quite similar except for the 480 finally getting metal handle. Profile of the top cover is a bit different. I have 3 480's I can build a good one from.
Offline DHansen
Re: Interesting fix
« Reply #7 on: January 19, 2023, 10:16:13 PM »
Don, do you slide the black piece forward to increase engine speed?   And we may joke about his fix, but it kept the saw in service.
Offline donbj
Re: Interesting fix
« Reply #8 on: January 19, 2023, 10:55:01 PM »
Exactly. The whole piece with the black thing attached slides back and forth under the two straps across it. Quite inventive. Just put your thumb on the black portion and push it up. Throttle return spring on the carb is more than enough to push it back to idle
