Adding Another Kiln and Pouring the Insulated Pad (Video)
Started by 123maxbars, August 02, 2020, 08:47:14 PM
123maxbars
I have decided to add a bigger kiln to the sawmill. I have been running the L53 with no issues but have always wanted  a bigger one for longer stock. I am getting the L200 from Nyle and a chamber with it also, not sure if anyone on here has that chamber yet, they said it's pretty new to their line up.  Last week me and my concrete guy formed and poured the insulated pad for the chamber. Nyle specified a pad at 10ft deep and 19ft wide. We went over a few inches and it turned out pretty good so far even in this hot TN summer heat. Spent the next few days keeping it watered down.  I am sure there are lots of ways to insulate a pad for a kiln but this is what I came up with,
http://www.youtube.com/watch?v=dxCQXSpdyig&feature=youtu.be
Sawyer/Woodworker/Timber Harvester
Woodmizer LT70 Super Wide, Nyle L53 and 200 kiln, too many other machines to list.
outofthewoods
Youtube page
Out of the
Fantastic Nathan!  You are going to be set up nice.
boonesyard
Sounds excellent! Can't wait to see the pics as it happens. Glad to see business warrants the expansion.
LT50 wide
Riehl Steel Edger
iDRY Standard kiln
BMS 250/BMT 250
JD 4520 w/FEL
Cat TH255 Telehandler
lots of support equipment and not enough time
"I ain't here for a long time, I'm here for a good time"
Walnut Beast
Looks great. Nice video. The new Nyle chamber is it in kit form or built already. What's the cost, made out of and the R factor.
samandothers
Nice job!  I look forward to the rest of your build.
YellowHammer
YellowHammerisms:
Take steps to save steps.
Be smarter than the sawdust
flatrock58
Nathan.  You keep adding stuff it is going to look like Jake's place pretty soon!
2001 LT40 Super Kubota 42
6' extension
resaw attachment
CBN Sharpener
Cooks Dual Tooth Setter
Solar Kiln
Walnut Beast
Quote from: Walnut Beast on August 03, 2020, 02:58:39 AM
K-Guy can you give any insight on this
K-Guy
Nyle Service Dept.
- D. Adams
scsmith42
Very nice video and congratulations on the new addition!
Tom's 3638D Baker band mill
Mossy Chariot
Hey Nathan,
If you keep adding equipment you may have to turn the cameras off and get to work  :D :D :D
Tony B
LT35HD, Riehl Edger, Woodmaster 725 Planer/Molder, Nyle 53 Drying Kiln, WM BMS 250, WM BMT 250, T750 Bobcat, E50 Excavator, Kubota 3450, Wallenstein Skidding Winch, Vermeer BC1250 Chipper, Stihl 250 & 460, Can-Am Defender
customsawyer
www.thecustomsawyer.com
stihlsawer
Good job Nathan and enjoy watching your and other sayers' successes!!
Trever
Trever Jones
Stihl 076 Super, 034, MS 260 PRO, MS 192T
Dolmar 116si
GB 44" lumber mill, Mini mill, Beam machine
terrifictimbersllc
GeneWengert-WoodDoc
This is awesome and certainly done correctly.  You can dry my lumber, as it is obvious you know what you are doing and are very careful.
rjwoelk
Just wondering about the insulation underneath the pad not coming to the edge of the insulated footing. The thought behind it   ???
Lt15 palax wood processor,3020 JD 7120 CIH 36x72 hay shed for workshop coop tractor with a duetz for power plant
GeneWengert-WoodDoc
Dry soil is an excellent insulator.  So,this is really good if drainage is away from the slab.
farmfromkansas
rjw, the gap around the edge of the slab is the footing.  Really like that bull float. You still need some dirt around the edge of your slab, don't want mice and rats to get to your foam.
rjwoelk
Here in the north I would have put insulation vertically as well at the bottom of the primiter to act like a form. That way you have a complete brake between cold and warm side. I understand he does not have 35 below weather.
