Author Topic: Turbosawmill M10-28 Auto For Sale - SOLD  (Read 177 times)
Offline WWDave
« on: January 08, 2022, 09:33:46 AM »
SAWMILL IS SOLD
I bought this mill new 1 year ago.  It has been a great mill.  The fuel injected Honda 30hp engine is very smooth and strong running.  This mill has a 10" cut capacity; 20" when double cutting.  I am a hobby sawyer, so only about 75 hours on it.  I am still using it so that number may go up a bit.  This machine uses insert-style blades which are very easy to sharpen.  Changing teeth is simple as well.  Available kerf sizes:  7.1 mm, 6.1mm, and 5.7 mm.  One blade will come with 6.1 mm kerf teeth while the EXTRA blade is fitted with 7.1 mm teeth.
Max log length is 20'
This mill has manual setworks which are accurate and easy to use.  The "Auto" function propels the saw carriage back and forth along the Beam.  The saw unit will automatically swing from horizontal to vertical at the far end so it is all set for the return cut.  There are many good videos demonstrating this on the "Turbosawmill" Youtube channel.
Included with the mill is a set of jockey wheels (NOT the 'trailer' option), blade sharpener, the tool to change teeth on the insert-style blade, and a spare blade.
The mill is located in Dudley, GA.  Local pickup only.  Asking $27,500
Reason for selling is to upgrade to the 12" cut Turbosawmill.
I have read, understand, and agree to the terms of posting an ad on the Forestry Forum.
Turbosawmill M10-Auto
Turbosawmill Electric Auto
Started by NZJake on Turbosawmill
Last post October 02, 2016, 04:43:37 PM
by Czech_Made
moved
MOVED: Turbosawmill Electric Auto
Started by Jeff on Sawmills and Milling
Last post October 02, 2016, 05:17:30 PM
by Jeff
Real world production numbers and use case with Auto Turbosawmill
Started by Horselog on Sawmills and Milling
Last post January 11, 2022, 06:57:53 PM
by NZJake
SOLD Used Woodmizer LT40 Super 40 for sale SOLD
Started by Chris Burchfield on For Sale
Last post July 31, 2017, 03:45:22 PM
by Chris Burchfield
