I run an LT-50 and considering buying a 6' bed extension.
I mostly do mobile milling for others. Is a bed-extension even practical for going mobile? I'd be concerned about setting up level out on location.
Or, are these meant for a permanent/stationary setup?
If you have a cable track then a 6' extension is all you can use so I am told. I have no experience with an LT50 or a mill with a cable track.
If you have a walk with the head mill, I would suggest buying a 12' extension. I purchased a 6' extension and it was a mistake. First time I used it I needed a 12'.
When the extension bed is bolted to the main mill, in my case, the mill is no longer mobile.
My reply to your question: Is a bed-extension even practical for going mobile?
Is the job large enough to warrant the work involved in mating the two in the field and unmating when the job is complete? I would be charging a handling/set-up charge.
Gerald
I think Jim Rogers goes mobile with his 6' extension, but I don't know if he takes it apart to move it.
I got a 24' extension, and the first time I used it. I needed a 6' also.
(https://forestryforum.com/gallery/albums/userpics/14240/1621/bx24_5.jpg?easyrotate_cache=1307496197)
Quote from: Dave Shepard on May 07, 2019, 08:16:05 PM
@Jim_Rogers (http://forestryforum.com/board/index.php?action=profile;u=95) - do you go mobile with a 6' extension?
Is it a major pain to set up and get level out on a jobsite......(on not so perfect, level ground)?
Thanks!
Dave - that's impressive. I'd love to be a part of milling timbers that length sometime! Very Impressive.
I have taken it to job sites. But I trailer it or have a friend with a pickup and tailgate crane move it for me to the site.
I don't try and take it with/on the mill.
I don't have any problems setting it up on gravel driveways or other hard surfaces.
Takes about an hour to hook up or un-hook. I charge an extra fee for moving it and for sawing longer than 16' on site.
Jim Rogers
good info, thanks
Dave,I always enjoy seeing that picture.
