Author Topic: Best firewood saw on the market?  (Read 5579 times)
Offline gman98
« on: May 06, 2020, 06:06:46 PM »
Hello guys, howís it going?  Iím looking to start a small firewood operation to make a little extra cash on the side.  Iíve got saws already but Iíd like to pick up a new one for firewood.  In everyoneís opinion, whatís the best firewood saw on the market?
Forest technician and part time equipment operator.  Looking to get set up with some logging equipment of my own.
Online sawguy21
Re: Best firewood saw on the market?
« Reply #1 on: May 06, 2020, 06:22:24 PM »
Opinions are like armpits, everyonne has them and they all smell. :D Are you looking new or used? What length of bar? Are you wanting a pro model or a farm/ranch saw? Do you have a servicing dealer with competent people and a good stock of parts nearby?  Stihl, Husqvarna or Makita will serve you well if you pick the right model for the job. A 50cc with 16 or 18 inch bar would be my choice for firewood, I don't want the weight of anything larger and it will all be smaller deadfall.
Offline gman98
« Reply #2 on: May 06, 2020, 06:48:14 PM »
Preferably new.  I never seem to have much luck with buying used saws.  Iíd like something with a little more torque than a 50cc saw.  Thanks for your input.
Offline lxskllr
  • dummy with saw
« Reply #3 on: May 06, 2020, 07:05:58 PM »
How about money? The obvious choices are Husky/Stihl if money isn't a problem. If you're on a budget, an echo 590 would be a good choice imo.
Offline gman98
« Reply #4 on: May 06, 2020, 07:22:44 PM »
I donít want to break the bank with a $1,000+ saw, but I want something quality.  Iíve already got the 60cc pro saws from both the big manufacturers and an echo 590.  I like all three of them, but Iím seeing if thereís something better out there.  I donít need a new saw, but Iím always looking for an excuse to buy one.
Offline Evanguy
« Reply #5 on: May 06, 2020, 08:15:36 PM »
Ms291 is a nice firewood saw for the price when they go on sale, but if you have a 60cc pro saw id use that. If you wanted to spend a good chunk a ms362 would be an awesome saw for firewood production
Online sawguy21
« Reply #6 on: May 06, 2020, 08:23:32 PM »
Doesn't sound like he would be happy with a 291. The next step up would be an MS462 or Husky 575 XP with a 24" bar, now we are getting into serious power
Offline thecfarm
« Reply #7 on: May 06, 2020, 08:56:16 PM »
You don't have your age available.
I myself would have a 50 cc and a 70cc. I had both for years. I won a Efco 50cc chainsaw on the FF. I had no idea that 70cc was the reason for my sore shoulder. ::)  Shoulder hurt for years, dummy me, kept swinging that 70cc saw. Used the 50cc for limbing and took a while but the pain started to subside. Took awhile for it to sink in why too.  ::) I use the big saw to cut down anything big and the small saw for limbing.  All was good until the crank broke off on the Efco. Need another small saw again. Might even drop down to a 40cc this time.
Offline gspren
« Reply #8 on: May 06, 2020, 09:58:27 PM »
Since you already have 60cc pro saws you will need to give more info like you want bigger or smaller or just want permission to get a new saw.
Offline Pine Ridge
  • Part-time logger, Full time loafer
« Reply #9 on: May 06, 2020, 11:13:29 PM »
Was looking at the saws you have listed, you already have the best firewood saw, 562xp, set it up with whatever length bar you need for the size wood your cutting. Light, very nimble and great power for a 60cc saw, with an 18" bar they cut fast.
Husqvarna 550xp , 2- 372xp and a 288xp, Chevy 4x4 winch truck
Offline Eddie Southgate
« Reply #10 on: May 07, 2020, 01:27:22 AM »
Stihl MS 261 C-M . Less than 11 pounds , 50 cc , 4.2 HP , does well with 16"-20" bars . With the RS chain they are cutting demons . Under $600.00 .
1997 Husqvarna 272xp 24"
1998 Husqvarna 136 12"-14"
2019 Stihl MS261 CM 16"-20" wearing an 18"
1966 ? Remington Super 754
2019 Stihl MS261CM  20"
 Stihl 0041av 20"
 Stihl 041av Electronic 20"
Stihl 044av
Stihl 056 Magnum II
1963 Ford 2000
801 Ford
Woodchuck
Offline Ianab
« Reply #11 on: May 07, 2020, 04:37:04 AM »
Also depends what you are lopping up for firewood. Many folks are slicing up 12" dia thinnings and tops and a 50cc saw does that just fine.
Locally you might expect to be slicing up 3-4ft dia Eucalyptus, and a MS660 isn't a silly choice.
Offline celliott
« Reply #12 on: May 07, 2020, 04:58:09 AM »
 Gman,  If youíre gonna be blocking firewood off a log pile, to sell, you want something fast. You already have the 60cc choices. You will be disappointed doing this with a 50cc. Iíd say 372/572 or stihl 462.
But honestly if Iím cutting on a log pile I prefer my 2188 jonsered. 20Ē bar, cuts real fast. A 372 may not be that much of an improvement over a 562, 20Ē bar, purely log pile blocking.
My 2 cents, get a 390xp and rock and roll  8)
Chris Elliott
Clark 666C cable skidder
265rx clearing saw
Offline gman98
« Reply #13 on: May 07, 2020, 05:57:20 AM »
Thanks for the replies guys.  I guess I should have added some more details.  Like celliot mentioned, itíll be piled tree length or semi tree length wood.  I have a 562xp and 362 right now, but I was wondering if anyone here knew of a better option.  Iím doing firewood part time on nights and weekends, so I donít have a lot of time to cut.  Therefore Iíd like something with some power.
Online doc henderson
« Reply #14 on: May 07, 2020, 06:01:12 AM »
sounds like fun.  You have 3 great saws.  are you missing a size?  are you going to be a one man show, or is the additional saw for employees of family to use.  how big an operation are you planning, or is this just to bring in some extra cash.  I like my 261 pro saw. light and powerful.   I use it on the mill.  I assume you are talking about hardwood.  what size logs.  I occ. split up old elm, that is 36 inches round.  I use a crane on my track loader to get it on the splitter.  I have an older 046mag,  and an 880 for really big stuff.  If you have all the saws you need, maybe a good sharpener to keep the chain sharp.
Offline Ianab
« Reply #15 on: May 07, 2020, 06:11:35 AM »
The 60cc saws you have are good ones. If you want faster, then you need more cc's, and that  means more money and weight.
I'd throw a Makita / Dolmar 790x into the choices, just because it's a 79cc pro grade saw that doesn't weight a lot more than a 60cc saw.
But saws in that cc / power range are all "pro" grade, and cost accordingly. They will all "get the job done" too.
Offline homeheater
« Reply #16 on: May 07, 2020, 07:03:01 AM »
You have fine choices in 60cc saws.  "Firewood saw"  is a term with so many variables.   60 is almost all I ever need to get the job done.  Can get by with 1-2 tanks per year on my 24" saw.  I would think you are getting awful close to the $1k you don't want to spend for a significant upgrade to what you have to get one new.  I could very well be wrong though because I am not in tune with the big saws.  I am loaded at 50-55cc and that's just what I need.
Offline Tom King
    • HistoricHousePreservation
« Reply #17 on: May 07, 2020, 08:51:07 AM »
Get a 261C-M from Mastermind.
Offline Al_Smith
« Reply #18 on: May 07, 2020, 09:05:42 AM »
First of all you'll never get rich by selling fire wood .That said every chainsaw ever made will cut the stuff .A 70 cc saw is a nice mid sized saw .For all intents they all cut about the same regardless of what anybody brags them up .Then it's how much you want to pay and how available is service for one .
Offline reride82
« Reply #19 on: May 07, 2020, 12:37:22 PM »
Gman,
When I started firewood about 15 years ago, I was using a 455 husqvarna, then about 9 years ago I stepped up to a 372xp, and this past few years I have been using a 395xp husqvarna. I cut and drag tree length to my processor and cut everything on the landing. If I had to pick just one saw, it'd be the 372xp, but the 395xp really speeds up the whole process. As a background I'm cutting dead standing lodgepole pine, 35 years old, 6'5" and 235lbs.
Levi
'Do it once, do it right'
'First we shape our buildings, then our buildings shape us'
Living life on the Continental Divide in Montana
firewood market
Started by treechopper40 on Forestry and Logging
Last post March 17, 2014, 05:38:21 PM
by timberjack 450
Firewood market
Started by Onthesauk on General Board
Last post November 20, 2008, 06:19:44 PM
by Onthesauk
Firewood business...big enough market to run a business?
Started by burnwood on Forestry and Logging
Last post August 15, 2014, 07:04:27 AM
by timberlinetree
Just Getting into Sawmilling! How to market wood? What Market?
Started by Ohio Logger on Sawmills and Milling
Last post November 03, 2016, 07:58:19 AM
by Ohio Logger
