Author Topic: PPB Sterilization  (Read 432 times)
Offline Stephen1
  • Where there is a will, there is a way!
    • muskoka Sawmill
PPB Sterilization
« on: May 04, 2021, 11:19:04 AM »
I have a customer that has 500 bd ft of reclaimed hardwood from a house built in the 1830's
The house was knocked down 40 years ago and the wood stored for 35 years outside under a tarp.
The wood was then put in a shed by this customer. He pulled some wood out to build something and discovered evidence of PPB. Not sure which type.
He wants me to KD and of course Sterilize it.
Easy enough in the IDRY as my temps go to 160F.
I have told him he will have to deliver the wood on the day of a kiln change over as I will not store his wood prior to or after KD. He will pay X$ per day , from 4-7 days as I think it will be a least 2-3 days to get the kiln above 135F and I would want it there for at least 2 days. He only wants to bring 500 bd ft and he will pay as if its a full load.
any thoughts would be appreciated.
I am not 100% sure I want to even do this job and that is why I am reaching out for some thoughts. I spend a lot of effort to ensure I do not have BUGS in my shop or in my storage yard location.
Stephen1
Offline Nebraska
  • Lurked for quite a while, learning !
Re: PPB Sterilization
« Reply #1 on: May 04, 2021, 12:43:23 PM »
Would it be worthwhile to have the customer soak the wood with solubor before it gets to your place?.... It would just be a surface treatment and  it should kill any emergence at your facility until you can pasteurize  the wood. Might be overkill but it would give you peace of mind.
Offline GeneWengert-WoodDoc
« Reply #2 on: May 04, 2021, 10:10:36 PM »
Remember that any pallets, 4x4s, stickers, etc. that do not go through the sterilization can 8nfect or reinfect KD wood.
Offline Stephen1
    • muskoka Sawmill
« Reply #3 on: May 10, 2021, 08:04:46 AM »
I have told the customer to take his wood and burn it. I do not really want a known infestation at my location. The money is not worth it. I am busy enough.
I do run all my stickers and blocking through the kiln on a regular basis
Offline YellowHammer
  • Sawing is fun for the first couple million boards.
    • Hobby Hardwood Alabama
« Reply #4 on: May 10, 2021, 12:20:48 PM »
Wise move.
smiley_thumbsup smiley_thumbsup smiley_thumbsup
YellowHammerisms:
Take steps to save steps.
If it wont roll, its not a log; its still a tree.  Sawmills cut logs, trees.
Kiln drying wood: When the cookies are burned, theyre burned, and you cant fix them.  So dont burn the cookies.
Sawing is fun for the first couple hundred boards.
question
Heat box for sterilization help
Started by Prinnie on Drying and Processing
Last post January 01, 2019, 09:46:27 PM
by farmfromkansas
Help with primitive sterilization box
Started by Jim gaster on Drying and Processing
Last post September 27, 2021, 10:40:18 PM
by willscot
Sterilization Cycle Really Works
Started by YellowHammer on Drying and Processing
Last post November 09, 2013, 10:15:33 PM
by WDH
Nyle Kiln sterilization
Started by Jstier on Drying and Processing
Last post June 17, 2021, 01:54:56 PM
by K-Guy
