Author Topic: Please help for brush cutter "Stihl FS550"  (Read 312 times)
Offline WildHunter
« on: May 23, 2021, 01:55:30 PM »
Hi,
I had a problem with my brush cutter "Stihl FS550" and when I opened it for checking I noticed that the blue wire of the throttle cable is cut (see photo) and without a connector and I could not find a terminal to connect it. Can you please help me locate the where I have to connect the blue
 wire by providing me with a schematic or a photo. Thank you.
Offline sawguy21
Re: Please help for brush cutter "Stihl FS550"
« Reply #1 on: May 23, 2021, 02:54:06 PM »
Online SwampDonkey
  • Large Tooth
« Reply #2 on: May 23, 2021, 05:56:15 PM »
Goes over that terminal, I pulled it out.
“No amount of belief makes something a fact.” James Randi
Online SwampDonkey
  • Large Tooth
« Reply #3 on: May 23, 2021, 06:13:18 PM »
Blue plugs into #32 (double terminal), a screw in the side holds the terminal.
Part #30 is the guide, 2 halves.
Offline Tom King
    • HistoricHousePreservation
« Reply #4 on: May 24, 2021, 01:15:55 PM »
Let it idle down before you cut it off.
My FS450K is an older model than yours, that uses the throttle cable to ground out electrical system to cut it off.  It would burn the throttle cable in two, if you didn't let it idle down first.  I'll bet there are many of those sitting around somewhere "because they don't run", with very few hours on them.
That was a common method for smaller string trimmers, but my theory says the coil in these is putting out more juice than the little string trimmers.
Online SwampDonkey
  • Large Tooth
« Reply #5 on: May 24, 2021, 04:25:16 PM »
Depends on who the owner is. :D  lots purchased by homeowners for the camp and some even by young fellers that quit about 3 days after they geared up to go spacing plantations. ;D But yes, there 'was' for a short spell a few being listed online when the 550 was discontinued. Never see them come up at all now on Kiji.ca
I had two 550's over the years, and ran them both over 10 years spacing trees. I did rebuild one though. I actually like the 550 over the newer 560, because it was lighter and same power. I probably cut an extra $200 a week, just because of that fact. Less fatigue. Back for the first year or two they were discontinued you could still get parts at the dealer.
Never did burn out a wire on them two saws, the throttle cable itself is all that ever went out on them, not the wiring.
