Author Topic: D37e-2 bevel gear shaft  (Read 391 times)
Offline Jkauffman
« on: October 12, 2021, 09:03:06 PM »
Ok so I’ve got a komatsu d37e-2 dozer that I’ve been redoing the steering clutches and brake bands on,and finally have all the parts and the time to reassemble.The first thing I noticed when starting to put it together is that the plate in the bevel gear shaft has a lot of slop in it. ::)(in other words the bevel gear shaft bearings are bad).Has anyone changed these?I have a manual but it has old black and white picks and is kinda a pain.I still have clutches out so I might as well fix it now.I don’t know much about dozers Lol as this is my first one maybe I should just get someone to fix it.Thanks for any advice
I should say I have a fair amount of mechanical experience and ain’t scared to tear into something(not enough anyways)and think I could fix it but just don’t know much about setting the bearing preload and gear wear patterns
Offline mike_belben
  • Pulp Friction
Re: D37e-2 bevel gear shaft
« Reply #1 on: October 12, 2021, 10:31:49 PM »
id like to help but i dont have the experience with them.  Try youtube?
Isaiah 63:10
Offline Jkauffman
« Reply #2 on: October 13, 2021, 06:30:57 PM »
I know this is a vain hope but if the clutches where in it couldnt move near so much but Im sure it aint normal.
Some how I have to make a puller that can pull up to 12 ton to pull the plate off the end because theyre pressed on.Dont know why they have to make it that hard
Offline Gary_C
  • Sunrise on the Prairie
« Reply #3 on: October 13, 2021, 06:46:07 PM »
Got any pictures or parts diagrams?
Offline Jkauffman
« Reply #4 on: October 13, 2021, 07:26:36 PM »
 The one picture is of the clutch housing you can see the plate on the left that will need to come off,than the other picture is of course the bevel gear itself and the other clutch is just outside to the left.Dont really have any parts diagrams
Offline mike_belben
  • Pulp Friction
« Reply #5 on: October 13, 2021, 10:57:25 PM »
I dont think we got all the pics you intended for
Isaiah 63:10
Offline Gary_C
« Reply #6 on: October 14, 2021, 12:33:09 AM »
Here is the other picture in OP's gallery. Doesn't help me much.
Detroit 3-53 Camshaft / Balance Shaft Gear Question
Started by JBMac76 on Forestry and Logging
Last post September 12, 2021, 10:24:34 PM
by Logger RK
question
Double bevel vs. single bevel broad axes?
Started by ziggy on Timber Framing/Log construction
Last post October 09, 2011, 10:35:45 PM
by ziggy
Vertical shaft to horizontal shaft conversion
Started by Doc Hickory on Sawmills and Milling
Last post June 08, 2012, 05:29:36 PM
by Al_Smith
correct axe bevel?
Started by knowslittle on Timber Framing/Log construction
Last post February 28, 2010, 10:55:24 PM
by knowslittle
