Timber frame brace and loads
Started by bannerd, April 06, 2022, 11:40:52 AM
bannerd
Does anyone have the calculation for bracing on the bottom of a post?  I know the longer the knee the more resistance but too long and it might be in the way of windows.
Currently I'm using 40" knees which I lagged into a 8x8 Sill pocket.  I'm trying to figure out how much pressure would be needed to shear the 8x8.  The 8x8 is 8ft tall.
We do have bracing above @ 40" as well which makes an X, curious to know the failure and are what weight.
bannerd
Species of wood is eastern white pine.
I'm going to say with X braces the lateral load is extremely high.  I'm just curious how strong these systems are.
Also, I'm sick of making knees... :)
Den-Den
I don't have the answer you are looking for.  I don't believe a single equation will cover the possibilities.
Failure modes that come to mind:
* compression perpendicular to grain in the brace pocket
* lag bolts shearing or pulling out
* post fail in bending above the lower brace (should resist a very high load)
* brace buckling (this seems unlikely to me)
The correct approach would be to check each of the above and any that I did not think of to find what fails first.
