Need Sharpening Service in/near CT
Started by james04, December 16, 2008, 10:37:05 PM
taw6243
It is original one from Woodmizer and profile gauge shows it still matches 4 degree
4500 hours on my 2004 LT40HDG28, CBN sharpener and auto setter, 25" woodmaster planer with 9'auto leveling bed and trac vac chip handling system, 1998 L3010 kubota, 2010 L3200 kubota Festool TS75 rail saw with 42", 75" and 106" rails.
Nomad
     Then it's possible someone from ReSharp mixed up the wheels they used.  Since you have a profile gauge, did you check one of the blades you received to find out what profile it was sharpened to?  It's also possible you inadvertently got somebody else's blades.  Stranger things have happened, I suppose.
WoodMizer LT50HDD51-WR
Lucas DSM23-19
I can say this, is is certainly bad form to come on here and start spouting if you have not been on the phone with wood-mizer to figure out what was going on. Very bad form.
taw6243
ThatWould be fine if they would answer the phone instead of just going to message and not getting a return call
taw6243
I will say, it is hard to get ahold of someone at Wood-Mizer when I call. I spend a lot of time on hold. However, when a tech answers the phone, they absolutely know what they're talking about👍
Chuck White
Just a suggestion:  Maybe it would be a good idea to get the phone numbers to more than one Wood-Mizer location!
   Good idea and suggestion. I think I have Indy, Atlanta, NC, Marty in PA and NY in my cell phone. They tend to back each other up. I'd call one and they'd be doing a road show or such and refer me to their counterpart who helped in every case.
Bluejay27
Your machine may be misaligned. Although I will say I have felt the 10 degree profile varied slightly from my WM cbn wheel, but it sharpened fine for me
'98 Wood-Mizer LT40HDD42 Super, '08 LT40HDG28, '15 LT70HDD55-RW, '93 Clark GPX25 Forklift, '99 Ford F550
taw6243
We were calling the resharp service for Woodmizer. And no cbn sharpener is not out of alignment
Dana Stanley
How many blades did you have trouble with? Maybe you grabbed the wrong blade, or do you only use 4*?
Making Sawdust, boards and signs.
Woodland Mills HM-126
Kabota B-7800 with backhoe and loader
Ford Ranger, Husqvarna 455 20", Mac 610 24", other chainsaws 14", 23 ton log splitter
Matthew 3:10
MartyParsons
Hello,
   The CBN profile have not changed. 4/32 is still the same. It would be best to call the location that did your blades. You can also call Wood Mizer 1 800 553 0182.  If the issue came from our location in PA Call me.
10/30 is a close profile and sometimes is confused with 4/32 without using a gauge.
Marty
Dana Stanley
Marty, Do the 8" and 5" CBN wheels have the exact same profile? Just a thought. I suspect a blade mix up is the problem though.
Matthew 3:10
MartyParsons
Hello ,
   there would be no difference between 5" and 8" wheel.
Marty
