Log splitter with vertical shaft Honda engine
Started by DaveP, April 18, 2010, 08:12:52 AM
DaveP
     Does anyone know of a way to drain oil from a vertical shaft Honda engine other then to tip the splitter?   Seems that I read something here and can't find it.  I ended up buying a TroyBuilt splitter.  Like everyone says, it is a great macnine.
shinnlinger
I would think an inexpensive drill pump or something similair would allow you to pump oil out of the filler port.
Dave
Shinnlinger
isawlogs
 Y'you'd think they would have put an access hole for the drain plug ...  ::)
   Marcel
I've gotta look at mine and see how it drains.
sawguy21
About the only way is to pump the oil out with a suction or turn the whole issue upside down, not an attractive alternative. Have a look at this or something similar.
http://www.northerntool.com/shop/tools/product_390306_390306
DaveP
     The owners book that came with the TroyBilt splitter says to tip the machine to drain the oil.  On closer inspection, I found a drain plug near the bottom of the fill tube.  Problem solved.  The Honda engine manual shows several engines but no drain plug.
nixon
Try this , it's called the liqivac . I've used one for a number of years on small gass engines .
http://www.liquivac.com/
Stihl            044 ,ms 460
Husqvarna.   346xp ,550xp, 562xp
                   372xp ,390xp, 395xp
