Timber harvester mill
Started by Stonybrookwoodw, January 31, 2020, 01:17:41 PM
Stonybrookwoodw
I am looking at a timber harvester mill 30TL19 and most information I can find is on this forum I can't find any info on the model number on this saw I know it's cable drive has a linamer lx 990 motor not sure wheel size or much else is there anything I should look for is it worth the time to go look at thanks
tylerltr450
Go look at it!!! I love my TH. If you want to change the cable to chain drive, look at my how to which goes over how to change it over.
If it has setworks I created a drop in replacement that will work for a TH mill and many others.
If you want to add setworks you can still use my new designed setworks.
send pictures we can help you out.
from the timber harvester website
[size=+1]At Timber Harvester, we recognize that not all sawyers have the same needs, or the same budgets. We've designed a full-function hydraulic mill, incorporating the most critical labor-saving features of our HT models, in an affordable package. With most logs the sawyer using a TL19 can grade saw as easily as with our most expensive mill. This mill shares Timber Harvester's fast log lift, clamp design, posts, and reversible chain turner with the HT models. The 30TL19 also features our dragback system, remote flow control, and remote control of sawhead. The mill is equipped with 19" band wheels, a dependable 24 HP gasoline engine, and full towing package.[/font][/size]
[size=+1]The hydraulic In-line Debarker is an available option with this model.[/font][/size]
[size=+1]Model:[/size]
[size=+1]36HT25[/size]
[size=+1]30HT25[/size]
[size=+1]30TL19[/size]
[size=+1]30H[/size]
[size=+1]30M[/size]
[size=+1]Construction:[/size]
Box Tubing 3" X 6" X 3/16"
yes
yes
yes
yes
yes
Twin Rail
yes
yes
yes
yes
yes
Heavy Duty Cross Members
yes
yes
yes
yes
yes
[size=+1]Features:[/size]
Main Frame Length (standard)
26 ft.
26 ft.
26 ft.
26 ft.
26 ft.
Remote Control
yes
yes
yes
yes
no
Dial Depth Indicator
yes
yes
yes
yes
yes
Saw Blade Guards
yes
yes
yes
yes
yes
Support Legs
yes
yes
yes
yes
yes
Electric Brakes & Lights
yes
yes
yes
yes
yes
DOT Approved Tires
yes
yes
yes
yes
yes
2" Ball Hitch w/Safety Chains
yes
yes
yes
yes
yes
Board Dragbacks
yes
yes
yes
optional
no
Log Length Capacity (standard)
20 ft.
20 ft.
20 ft.
20 ft.
20 ft.
Log Diameter Capacity
36"
30"
30"
30"
30"
Bandwheels 25"
yes
yes
19"
19"
19"
Saw Blade Lengths (all .042" thick)
16'8"
15'8"
13'11"
13'11"
13'11"
Saw Blade Widths
1-1/4" or 1-1/2"
1-1/4" or 1-1/2"
1-1/4"
1-1/4"
1-1/4"
Hour Meter
yes
yes
yes
yes
yes
[size=+1]Hydraulics:[/size]
Log Turner
yes
yes
yes
no
no
Log Loader
yes
yes
yes
no
no
Log Tapers
yes (2)
yes (2)
no
no
no
Log Clamps
yes (2)
yes (2)
yes (1)
manual only
manual only
Log Posts
yes (2)
yes (2)
yes (2)
manual only
manual only
Sawguide
yes
yes
manual only
manual only
manual only
[size=+1]Powerplants:[/size]
24 HP Gas (air-cooled)
yes
yes
yes
yes
yes
30 HP Deutz Diesel (liquid-cooled)
optional
optional
no
no
no
40 HP Deutz Diesel (liquid-cooled)
optional
no
no
no
no
20 HP US Electric 3 phase
optional
optional
no
no
no
25 HP US Electric 3 phase
optional
optional
no
no
no
Timber Harvester 36HTD25 fully loaded
2006 Dodge 2500 first Auto to NV5600 swap, EFI Live Tune by me
John Deere Tractor
Massey Ferguson 711B SkidSteer
Stonybrookwoodw
So this mill compared to the ht the couple options that it doesn't have and the smaller band wheels is that something I'm going to kick myself for not having in a mill or something I would only notice running full time I'm new to saw Mills I'm not new to lumber I do alot of woodworking and I know logs cuz I buy my own logs but always had them milled else where and want to bring that in house so would be milling quite a bit but not full time I'm hoping to get out to look at it soon and so setworks is something you can add to this mill i feel that what would be a nice option to have
tylerltr450
Quote from: Stonybrookwoodw on January 31, 2020, 03:46:21 PM
Correct the mill you have is almost a HT you are missing the setworks.
If your looking to add setworks let me know the system I made should be an almost drop in system for you.
John Deere Tractor
Brad_S.
The TL has no toe boards, only one clamp and the guide arm is manual.
All mills were made with 19" wheels back in the day and there was/is no problem with them in actual use. The only real downside is the flex that they put on blades, slightly decreasing the blade life.
I am a huge TH fan. I believe any model TH is the best within their given class. If you will be a hobby sawyer, that mill will serve you well. If you want to saw for production though, you may want to consider a mill that is fully hydraulic with no adjustments needing to be done manually. Just my 2 cents worth.
Patpollin
Thank you for posting the specs on the model range
I am looking into a 30HT near me.
Do these have toe board adjustment?
What type of hydraulic hose life should one expect from a hydraulic mill, a
I am looking at a 90s or 2000s mill on original lines? When is a full reline due? Not stored inside, looks like an outside machine.
Tyler I am interested in pricing on your setworks
tylerltr450
Mines are still original and its a 2001 lines should last a long time
John Deere Tractor
