white oak stain
Started by Jeff, April 08, 2013, 10:17:49 PM
I'm working on sprucing up an old Forest Service Field Phone. I've got the wooden box stripped of all of it's hardware.  As you can see by the photos, there is quite a bit of dark stain on the quarter sawn oak. I think I already know my answer, but is there anything I can do about it, or is it what it is? :)
Much of it will be back under the hardware, but not all of it.
Oxalic acid would be the best bet, IMO
http://www.realmilkpaint.com/oxalic-acid-bleach.html
Or a strong bleach solution to give an idea if the stain is "removable".
At least don't think it can hurt the wood any.
mesquite buckeye
Iron on wet wood is bad news. :-\
Its not iron. It's all painted brass. Brass screws as well.
mesquite buckeye
Think it is just grunge and mildew, then?
It looks like a tannin stain, but shouldn't be with the brass. The photos are after a good sanding, but I'm sanding with a 150 grit to start. I don't want to remove any more wood than necessary to clean it up. The wood is good and sound.
mesquite buckeye
Is is possible that they used brass plated steel? That also could explain it.  ??? ??? ???
mesquite buckeye
My dad could have helped you with all the old phone stuff. He was Army Signal Corps telephone maint to forward OP, Phillipines, 1945. Too bad he is gone for 16 years now.
Quote from: mesquite buckeye on April 08, 2013, 10:35:30 PM
Could be. I've not got into cleaning that up yet. Maybe they just spilled lots of coffee. :D
Jay C. White Cloud
I would clean it all up first with soap and water, then a little bleach dilution.  If you are still wanting it cleaner, go with what Beenthere suggested, "Oxalic acid."  If that don't get it, I don't think anything will without causing more harm than good.
mesquite buckeye
Maybe. Bet it was rained upon many a time. Hope it turns out nice.
When I get less buried with stuff I have to do, I'll post some pictures of my Great Great Uncle's woodworking tools. I can tell you like that old stuff. These came across from Germany in the 1880's.
Tree Feller
Another vote for Oxalic acid. Wood bleach is hydrogen peroxide and sodium hydroxide (lye). It is I good at removing stains but will remove the color, too.
Those are nice box joints on that case.   :)
Cody
Logmaster LM-1 Sawmill
Kioti CK 30 w/ FEL
Stihl MS-290 Chainsaw
48" Logrite Cant Hook
Where would Oxalic acid be readily available?  Home Depot?
Tree Feller
I think I remember seeing it in our local Home Depot but a paint store will definitely have it.
Cody
Kioti CK 30 w/ FEL
You could always distill it from wood sorrel this spring. ;D :D If I hear ya talking with a lisp, I'll know you got into it. ;)
Axe Handle Hound
Jeff- oxalic acid is sold as "wood bleach" at placed like HD like Cody said or even at Menards if you have one of those nearby.
Thanks for the sage advice gentlemen. Almost all the stain is gone. There is a little remaining in a couple spots, but it is where it will be covered. It may disappear yet on this third application. I don't want to do any more than I need to, as it does raise the grain some.
Home Depot has discontinued all wood bleach products according to the store I visited. I found the Oxalic acid in a small hardware in Houghton lake, sold as a product called wood bleach.  :)
 It needs to finish drying out so I can finish up the sanding.  :)
ely
Jay C. White Cloud
Hey Jeff,
Very Nice! keep the pics coming as you restore it.  Looks like you will have a real nice piece.
Regards,
jay
Tree Feller
That is a nice transformation. I'm glad you found something that worked.
Cody
Kioti CK 30 w/ FEL
barbender
That's a neat piece, and I see you put the Menard's flyer to good use too ;D
I finished the case a few minutes ago. Didn't realize it was tomorrow already. :) Thanks again for the advice. :)
By the way, the brass vent screen in the first photo cleaned up amazingly is ketchup!  Left it soak for about an hour, and it rinsed clean like you see it.  8)
That is a pretty impressive re-do. Looks great.
