Funny noise, horrible cut.
Started by Dave Shepard, March 06, 2016, 06:47:52 PM
Dave Shepard
Switched over from sawing some oak trailer decking to cutting pine this afternoon. I had some help, and he put the last sharp Turbo on the mill while I was moving some logs. The saw would hardly cut, was making the worst waves I've ever seen. I thought maybe I had a bad guide roller bearing the way it was making this weird noise. It turns out that the last band in a flat pack can get turned inside out when you take it out of the clip if you aren't used to handling bands.  :D I've never done it before, but at least now I can tell you what happens when somebody else does. :D
drobertson
 :D :D :D thanks for the warnig :D  I've done it but, put on inside out,, I mean then the ole double take look, that aint' right,, off and flip,, yea, that would make a wavy cut,, :D
bkaimwood
That's funny, Dave!!! Ironically, I read your first two sentences, and was ready to fire away with, "was there smoke?"!!!! Same thing happened to me a couple months ago..I mean exactly... My bet is the band was packed right, and the installer caused the issue. It was the first time anyone other than myself changed a blade, and the last!!! Good news is, it didn't wreck the blade, just cost 5 or 10 minutes....
bk
Chuck White
Been there, done (part of) that!   ::)
Put a reversed one on once and noticed it when I was tensioning the blade wheels!
