Thinking through a startup
Started by Horselog, January 19, 2016, 08:10:18 PM
customsawyer
The log deck is a WM. When I first started down there it took me a little while to learn some tricks to cutting the bigger logs. Once you get them figured out you get to where you like them.  ;D
www.thecustomsawyer.com
280 rem
The chains on my 20' WM log deck wouldnt even budge if there was a semi truck load of logs sitting on it, or at least they wouldn't with a quantity of little less than half of that I know for sure. Still trying to picture that much sitting on, would be a sight worth seeing :o
We saw walnut lumber for the same reason Willie Sutton said he robbed banks, "because that's where the money is"
Select 4221E, baker edger, cat 908 loader, Jd 548E, timberjack 230d, hood 7000 loader.
