flotation tire question
Started by RR construction, December 29, 2021, 07:21:21 PM
RR construction
very silly question i know i know, 1995 tj 230a currently on 66 x 43 -26, any chance a 66 x 43 -25 tire would fit? cant find any -26 and the -25 are priced very well
kiko
Don't think it would work.  The 26 and 25 is the rim size. Doubt you could stretch a 25 inch tire onto a 26 inch rim  without busting the bead.
RR construction
i figured so, thought i would ask thank you for the reply cheers
Southside
That's a big tire for a 230. What kind of ground do you run on?
White Oak Meadows
mike_belben
Praise The Lord
Riwaka
Probably be a goodyear-titan arrangement, tire. or 2 types that size in Firestone. (Check rim type and compatibility)
Bottom of page flotation etc.
Goodyear Titan Forestry Tires ? SkidderTires.org Wholesalers
RR construction
Quote from: Southside on December 29, 2021, 08:19:58 PM
the machine is new to me and 2 tires is cheaper than 4 lol  i know they are abit big but would like to keep with the wide tires to be as stable as possible im upgrading from a tippy c4
