help stihl 066 parts diagram for trigger assebly needed
Started by carver45, January 12, 2009, 08:52:07 PM
carver45
Hello everyone,
I really could use some help. My o66 stihl has been acting up lately since our repair guy took of a styrofoam sock that went over the filter. Well I am tired of taking it the repair shop so I got up the courage to look at the carbuator fuel filter. It was clogged big time.(or I should say the jets) Well I have  no problems with the filter or assembling that part.
The problem is, I took apart the handle thinking that it was a logical to do. Well then the whole trigger assembly exploded when the spring let loose. I have it almost figured out but I have one very liitle black piece of plastic left over that is about a half inch long with a hook on it. If any one knew where a diagram of the trigger is, it would be very appreciated.
Thanks for any help
Christopher
L. Willey
sounds like the part that hooks onto the throttle linkage.  maybe if you could post a pic
the trigger pushes on it then the hook connects into the little steel throttle linkage. hard for me to explain sorry the best i can do.
sawguy21
carver45
Thanks for the suggestion,
Here is a picture of it. It is really nice of everyone to reply, it helps alot with the frustration level.
The link above you need a dealer number.
MartyParsons
The item you have is part of the master control switch it go on thr right side of the shaft & fits down into the housing to hold the switch shaft in place
Hope this helps
carver45
joe_indi
chep
There was a great picture/diagram of the 066 assembly here, for some reason the picture wont show up now?
Is it my computer or can it be reposted please!!!
thanks
