Pole saws
Started by Stephen Alford, March 09, 2021, 03:10:11 PM
Stephen Alford
   For quite a few years stihl made a HT 131 pole saw. Then they started producing a newer version called the HT133.  From what I can tell the newer model has a different style shaft and seems to be more plastic or maybe its some composite.  They were roughly the same price but now the newer version is running a couple hundred dollars cheaper. I borrowed one of the older style to try on the last job and they seem like a very useful tool. Worked well for pruning next to buildings and cutting trails for the tractor. Just wondering if anyone has any experience with these ?   Appreciate any insight as to use and maintenance.   Thank-you.
logon
mike_belben
well.. i sorta built one to put on my 131 trimmer/clearing saw.  i bought a $20 knockoff head on a chance, not thinking it was even gonna be real.  i figured its a pic of the whole thing but will be just the part.  well.. it was the whole thing, shipped from an apartment in brooklyn in like 3 days, with new bar and chain for $20. standard chinese warfare.
i built an extension shaft and a driveshaft and a spline for it and its handy but in 20 mins mine started twisting the splines, which were made from weld on a piece of mild steel junk rod.  i can't say I'm surprised.
there are 3 drive styles.  square drive here in america is standard, on a 1" OD pole.  then in europe they seem to have mostly used 7 spline on 26mm pole.  and now there is also a 9spline drive.
my stihl has a 1" pole and .25 square drive.  i could not find ANY adaptation from square to 7spline.  the 26mm wasn't too big an issue, as a pipe tap threaded right into the chicom saw head and allowed it to be clamped to sch40 water pipe.  but thats pretty dang heavy.  you could find aluminum tube and use plumbing die to thread that if you can't find 26mm OD tube to build the extension.
basically what I'm saying is there is no black magic in making a pruner attachment for your clearing saw if you have a lathe and basic metal skills. the 9spline drive is probably strongest but square drive is stupid easy to make with a piece of drill rod.  make sure you have a plastic bushing in the bottom to keep the driveshaft centered or its almost impossible to put the extension together.  the shaft will just lay on the bottom of the tube and never mate to the shaft in the power unit tube, which is centered by a bushing.
Praise The Lord
Stephen Alford
   Oh man now that's a "weapon" gives the ol line...headed for da roses.... a whole new perspective.    Maybe the cheaper model is European stock they are trying to move and have dropped the price because the square drive is more durable and preferred.  How do you like the bike handles as opposed to the D shape for working over your head. ?
logon
Walnut Beast
Quote from: Stephen Alford on March 09, 2021, 03:10:11 PM
Those type work great. I've got a power pruner it's extendable like the Stihl. It's got a echo engine on it
mike_belben
Quote from: Stephen Alford on March 09, 2021, 09:38:44 PM
Well.. It's the only one ive ever tried and only for about 10 minites of actual work so i dont really know.  Its cumbersome but its also like 15ft long i think.  Its easier to use with the bars as pictured than when theyre perpendicular.  So my right hand is on the trigger and left hand is up on the pipe near the trimmer head to have some control.
Its cumbersome to use for sure but maybe they all are to some extent. Id like to try a real one but i think theyre a lot shorter and all aluminum so not quite the same tool anymore.  No one asks a 16ft ladder to carry like a 6footer.
Praise The Lord
thriceor
I have an Echo/Koritz. Don't recall which model, but it it the fizz for cutting overhead.  Extends to about 15 feet, so yah gotta sorta be in shape.  Super reliable though.
...I'd rather trust a man who works with his hands,
He looks at you once, you know he understands...
Genesis- "The Chamber of 32 Doors"
Stephen Alford
   Welcome to the FF thriceor . Is it for personal use or  do you do do pruning work ?  Pole saws are not that common here and there seems to be a bit of work for them.  Saws and operator get about 30/hr .   Any pics from your part of the world ?
logon
mike_belben
Thats what i charge to run the clearing saw and in this part of TN thats what an RN makes.   Its more than double what my phlebotomist wife gets with 20yrs experience.
Praise The Lord
Old saw fixer
     I have a Stihl HT 132 pole saw.  It adds about 7 feet to my reach and weighs around 13 pounds ready to go.  I purposely did not get the extendable HT 131, since I am not the powerful young man of my 20's any more.  All I need is to clear limbs that are in the way of cutting grass around the house and pond.  The pole saw is also good for clearing tangles of limbs and trees brought down by the recent ice storm.  I am a one man team and have to work carefully.
     The 131 and 132 pole saws have a 36.3cc 4 Mix engine, with an advertised 1.9 bhp.   I am told that all the Stihl pole saws use the same saw head, all but the HT 250 come with that darn ΒΌ picco chain, the HT 250 comes with 3/8 picco chain.
Stihl FG 2, 036 Pro, 017, HT 132, MS 261 C-M, MSA 140 C-B, MS 462 C-M, MS 201 T C-M
Echo CS-2511T, CS-3510
Logrite Cant Hook (with log stand), and Hookaroon
thriceor
Thank Stephen.  It is for personal use, I have about 30 acres of woods I battle honeysuckle in.  It is an old PowerPruner.  What I meant to say is I can reach about 15 feet away, it probably extends to about 12 feet.  I'll try to get some pics.
Stephen Alford
   Well Mr Mike that is the crazy part of it.  You can get 30 an hour with a chainsaw and  with a polesaw or commercial clearing saw like the fs 560 you may be able to get 40 an hour. They are not that common and folks don't want to put out a lot of coin for that kind of a saw. I am going to check and see if the rental places carry them.  For a tractor and implements and they wont pay 35 an hour...go figure.     The mentality these days is why buy if you can borrow.   :(
    Looking forward to your pics Mr thriceor.
    Good catch Mr fixer...checked today and the new HT 133 has that 1/4 picco. The HT 131 is a little more robust with the 3/8 picco.  That is more appealing.  I notice you have a stihl 261 c-m....would be great to get your opinion on how you find it performs.  Thank-you  :)
logon
Old saw fixer
     Stephen, my 261 C-M is very smooth and starts easily.  Mine has the new type 3 carburetor control system that may have gotten rid of the earlier bugs like hard or no start and etc.  I wanted the 16 inch bar because it will cut anything I ordinarily come across in my timber stand improvement.  I do have options available if needed.  No buyers remorse here!
Stephen Alford
    Good to know...I thought they might be nice for trim work. At the moment they have been on back order since November.
logon
VirginiaFarm
I stihl am a powerful young man in my 20s and I have the HT131. Fantastic pruning saw for getting higher limbs from the ground. One of my favorite uses is to drop lower cherry and oak limbs with it. I use it to cut around 20" long pieces so the firewood rains down and I don't have to use the chainsaw to cut smaller, unwieldy pieces. Also great for cutting vines, dead limbs. A great tool for timber stand improvement.
Have also used it to dispatch a fairly aggressive snake by the house one time.
I was looking at a battery powered one. This is a tool that I will use around the fields and than it will not be used until the branches start to bother again. I suppose I will use it on the woods roads too.  ;)
I use a manual Fiskars out on the woodlot. I can reach up a lot further, and fir branches are easy to cut. I have a 12' reach. A lot lighter to hold over your head. ;D Plus I can leave it out there.........well the bears do find them. Those crazy monkey bears. ;D
Stephen Alford
   Good to hear the endorsement Mr VirginiaFarm  for the HT131...man...you would really get attached to a fs560 clearing saw... :)
   Looked at the battery power one Mr Cfarm  .... they are not that  much lighter and I wonder how those batteries would stand up to snow and sub zero temps. Some of the work being discussed will be trail and driveway maintenance.  When we get one of those wet snow or just heavy snow events branches lower substantially. But it is also an opportunity to know what to trim.
   The one I had Mr SD did not seem to work well in hard woods. Here there is a highly sought after and much valued realty  asset ....water view.  Trees cant be cut but there are no provisions regarding...limbing... ;D   It is really quite a standing local joke...a small kiddies splash pool on the front lawn qualifies as a....water view ... when the home goes for sale. :D
logon
PoginyHill
Quote from: SwampDonkey on March 12, 2021, 03:50:29 AM
Glad to know I'm not the only one that likes to prune spruce/fir - with a manual pole. Makes walking around the woods a bit easier and maybe someone will enjoy clear lumber someday. And it's the only workout my biceps/triceps will generally see.
Kubota M7060 & B2401, Metavic log trailer, Cat E70B, Cat D5C, 750 Grizzly ATV, Wallenstein FX110, 84" Landpride rotary hog, Classic Edge 750, Stihl 170, 261, 462
Yeah, and the photo there is deceiving, because a lot of them knots are internodal shoots that come out the second year, and not whorls. ;D Long ways between actual whorls. ;) I only prune the special ones. As far as seeing around the forest the crown has lifted a lot naturally, with most them low limbs being dead. My ground was all thinned with a clearing saw 10-16 years ago: 2005, 2007, 2011. Growing like gang busters.
thriceor
Quote from: Stephen Alford on March 11, 2021, 07:06:44 AM
Stephen, here are a few pics:
 The neverending honeysuckle battle:
 the maple grove I've been thinning for a few years:
Are you getting any maple regen yet?
treemuncher
I'll cast a vote for the Echo dedicated Pole Pruner. I've had mine close to 20 years. Not fun to run but it is dependable and fast when the chain is sharp. Only repairs that I've made to it was the inner support bearing kit.
It was about $600 when I bought it IIRC. In the long run, it was well worth it because it is so dependable.
TreeMuncher.com  Where only the chosen remain standing
Tom King
Mine was new in 1999, and I think it's an HT85, but don't remember exactly (eighty something).  It's still working fine.
The one I end up using the most stays in the toolbox on the pickup.  It's a cheap, 20V Ryobi.  It doesn't cut anything like as fast as the gas fueled one, but comes apart into three pieces that fit fine in the truck toolbox.
thriceor
Quote from: SwampDonkey on March 25, 2021, 02:54:22 AM
No new growth that I've noticed.  I'm just trying to help the better trees get bigger and make the area look nice.
mike_belben
42ish yr old maple stump in wife's friend's backyard.  3/8ths to half inch growth rings from about year 10.  I dont know for sure what type but we tend toward red maple.  Very dark, moist, and thick topsoil.
Front yard
Praise The Lord
