Author Topic: Massey Powershuttle? Yorque converter squealing !  (Read 482 times)
Offline Satamax
  • Living in Absurdistan!
« on: July 10, 2021, 05:16:18 PM »
Hi everybody.
My crane has a "powershuttle" transmission
I understand that there is a torque converter in there.  When i drive, the thing squeals, like a loose belt. But it isn't a belt.
Anybody ever heard that?  What was the culprit? If ever you found out.
I know that a filter change is long overdue. But i can't seem to unstick the filter bowl. 3/4 ratchet, with breaker bar doesn't do it.
Well, if anybody is more savy than me on those, i'm all ears.
Thanks guys.
Offline Satamax
Re: Massey Powershuttle? Yorque converter squealing !
« Reply #1 on: July 11, 2021, 02:54:16 PM »
Here's the insides.
It's a welded torque converter. Oil fed from the "nose" .  I will change both filters.  The return one seems clean. But I'll change it anyway. The pressure one is black. So that's for sure a replacement.
Offline mike_belben
  • Pulp Friction
« Reply #2 on: July 11, 2021, 03:02:36 PM »
A non lockup convertor is usually just two housing shells with fins brazed inside and a stator plate assembly.  If its truly inside the convertor i cant think of what it would be.
My quad has a single complex sealed brake assembly on back axle that has normal rubber seals and that thing squeeks so loud you can hear it for a mile.  I think your squeek is more likely to be the convertor hub squeeking on a rubber seal in the trasmission pump than it is to be from inside the convertor itself.  If i swerve around the weight on that hub will start or stop it.
Isaiah 48:10
Offline Satamax
« Reply #3 on: July 11, 2021, 06:13:38 PM »
I'll know more once the filters will have been changed.  Massey manual says  no problems can come from the torque converter. Rather from the pump feeding it.
Offline Satamax
« Reply #4 on: July 12, 2021, 03:18:53 AM »
And there is "electric hydraulic" forward and reverse. And clutch is ?? ?? . I mean, to change speed i need to press a button on the stick. And forward ans reverse are actuated with a switch at the wheel.
There is two hydraulic distributors, one big one, for forward and reverse. And one on the side, for the selecting the 4x4 mode.
But i haven't seen the clutch. But as i have seen on some diagrams from other machines, it could act on the torque converter. Freespooling it. But i don't know much about it.
Offline mike_belben
  • Pulp Friction
« Reply #5 on: July 12, 2021, 08:01:27 AM »
Wish i could help but i have no idea max.
Isaiah 48:10
Offline Satamax
« Reply #6 on: July 13, 2021, 12:03:46 PM »
Finally found the two filters. May they'll be here by Friday.
Squealing drive belt
Started by Chuck White on Sawmills and Milling
Last post July 13, 2008, 08:45:37 PM
by Chuck White
Hydraulic pump squealing
Started by Tony on Sawmills and Milling
Last post July 09, 2021, 10:28:53 PM
by mike_belben
help on a massey
Started by dancan on General Board
Last post May 19, 2007, 09:03:01 PM
by isawlogs
Massey skidder
Started by NCLogger on Forestry and Logging
Last post January 15, 2017, 09:32:32 AM
by Ohio_Bill
