Whatcha Sawin' 2019 ???
Started by Magicman, March 08, 2019, 08:46:24 AM
tule peak timber
Headed my way after the first of the year, 37000 lbs net. Merry Christmas !
Bruno of NH
What are your plans for it?  what kind of wood?  how will you move it?  uuuuuuuuge.
Brad_bb
That is a monster Tule, but I'm sure not your first.  What about the black marks showing on the end? Just go for it and sacrifice some bands?
tule peak timber
This is a black oak that will be delivered in three truck loads from N. California.Not sure , or worried about the black stains at this point. I bought back my slabbing mill from the same gent that also bought my LT-70 wide to cut this stick but I don't think it will fit ??
  Got out of the slab business a year ago when I saw too many folks getting in and destroying the market. I have a use for the slabbing mill later in 2020 so I might as well start bringing logs in again.
 When it gets here we will par-buckle off the trailer and slice into table tops .This requires bunking under the trailer frame and a bit of thought as to where the log lands for milling. It took two 900 series cats to load at the other end and I'm one cat short at this end :D
btulloh
Wow.  That's a big stick. Looking forward to seeing it opened up.
HM126
alan gage
Holy cow! In a regular sized tree those iron stains would be from nails. These are probably railroad spikes.
Alan
May hafta dig a hole, back the trailer into it, and roll the log off on level ground.  ;D
The blue could be from the bar/chain while falling/bucking which would be easy to determine.
SawyerTed
So I sawed yesterday and today cutting cherry, ashe and cedar.
The photo below is a load of Cherry.
After the previous posts, I feel like the old men on the bench in front of the courthouse in Andy Griffith - just whittling sticks.
GAB
It's been said go big or go home.
Apparantly he doesn't want to go home.
I'll be watching for pictures as I'm curious.
A 4" thick slab in the center may require his cat.
GAB
Southside
Who are you making tables for?  Shrek?  :D
tule peak timber
I'm still getting calls for "stupid' big tables and doors that I'm making out of a dwindling stock pile. Walnut sells the best but anything huge has a market, at least for now.Don't know how much longer the slab market will last--my best guess was wrong last year. Time to shine my crystal ball.....
GAB
Quote from: tule peak timber on December 21, 2019, 08:12:51 PM
And I always thought that crystall balls had to be calibrated.
GAB
tule peak timber
Well,,,sign me up. I've been wrong before ! :D :D :D
Herc102
Amazing log!  This is my first post.  Just purchased an hm126, hoping to play with it in retirement.
tule peak timber
Welcome to the site . Lots of logs ,,dogs ,, and knowledge here.
WOW and another WOW!!!! How many feet across is that? I cut some big pine on my land,4 feet across,and those made the ground shook when they would hit the ground. That really must of did some shaking!!!
Welcome Herc102. Finish filling your Profile with your location, etc. so that we will know/remember.  :)
tule peak timber
Quote from: thecfarm on December 21, 2019, 09:29:16 PM
Bought it ---haven't seen it . My wife tells me I'm writing checks my body can't cash......
redbeard
Wow!
Monster and Heavy too boot!
Bruno of NH
I thought the slab craze fell out this summer.
I was wrong once September hit sales picked up.
3 to 5 a week .
Some weeks 10 + mostly hardwood.
I still plan for a slow down.
Quote from: tule peak timber on December 21, 2019, 09:35:18 PM
A man has to be adventurous.
boonesyard
 whiteflag_smiley whiteflag_smiley whiteflag_smileyWow, incredible
LT50 wide
Riehl Steel Edger
iDRY Standard kiln
BMS 250/BMT 250
JD 4520 w/FEL
Cat TH255 Telehandler
lots of support equipment and not enough time
"I ain't here for a long time, I'm here for a good time"
Poquo
I feel like I'm cutting toothpicks after seeing that log !
2015 Woodmizer LT40HD26
