Author Topic: Drying time for cookies  (Read 938 times)
Offline BLJ
« on: July 17, 2019, 05:46:50 PM »
 A friend of mine approached me recently about sawing some decorative cookies for his wedding.  It's in October. Would I be better off to saw them the week before to limit cracking or saw them now and take a chance.  I'm thinking the week before to limit the possibility of cracking but I'm looking for other opinions . Thanks
Offline barbender
Re: Drying time for cookies
« Reply #1 on: July 17, 2019, 06:43:07 PM »
I've did a couple of those, I sawed them shortly before.
Offline doc henderson
« Reply #2 on: July 17, 2019, 07:19:36 PM »
what kind of wood.  rough sawn or sanded and finished?  what diameter, for each table or head table to sign?
Offline Stephen1
  • Where there is a will, there is a way!
    • muskoka Sawmill
« Reply #3 on: July 17, 2019, 10:56:00 PM »
I used to saw them 1-2 days before .Now with the IDRY kiln I saw thm by the hundreds and dry them in 4-5 days. I only loose about 10%  to cracking. Now they can be sanded and finnished.
Offline YellowHammer
  • Sawing is fun for the first couple million boards.
    • Hobby Hardwood Alabama
« Reply #4 on: July 17, 2019, 11:40:55 PM »
I saw mine the week before and prefer to use relatively low crack prone wood.
Eastern red cedar, soft maple, pine, and box elder work great.
YellowHammerisms:
Take steps to save steps.
If it wont roll, its not a log; its still a tree.  Sawmills cut logs, trees.
Kiln drying wood: When the cookies are burned, theyre burned, and you cant fix them.  So dont burn the cookies.
Sawing is fun for the first couple hundred boards.
Offline BLJ
« Reply #5 on: July 19, 2019, 09:36:51 PM »
Wood options would be red oak, EWP, hard maple, yellow poplar, wild black cherry, hickory, and possibly black walnut.  I have no access to a kiln. They will probably be sanded some to knock the edges down. No signatures that I know of.
« Reply #6 on: July 19, 2019, 09:46:32 PM »
oak tends to split long term, walnut is better.  larger diameters also have more stress due to the shrinkage.  12 inch walnut is good, soaking in alcohol decreases splits. but short term will be ok if you want to throw them out after.  I soak mine, dry in a box, sand on a drum sander, and finish with Danish oil.  I have about 50 stored.
« Reply #7 on: July 19, 2019, 09:48:59 PM »
some are using them for the head table for people to sign like a guest book.  some are putting a cookie on each table with decorations like a mason jar with flowers and or led lights.
Offline BLJ
« Reply #8 on: July 20, 2019, 07:28:09 AM »
Speaking briefly with the groom, I gt the impression that this will be a one time deal and thrown out afterward.
Offline GeneWengert-WoodDoc
« Reply #9 on: July 20, 2019, 10:06:59 PM »
For our 50th anniversary, our daughter ordered disks from Walnut Hollow in Dodgeville, wi and they worked perfectly.  This might be a painless way to handle this.
I did visit them and they were drying disks with over 97% success rate.  They had a hot air kiln.  Do not know how they did it so well.
Offline Southside
    • White Oak Meadows
« Reply #10 on: July 20, 2019, 11:33:08 PM »
375 for 16 minutes, butter the sheet, leaves a gooey center with melted chips and a crispy outside. You don't want them dry, much better this way.  :D
White Oak Meadows
« Reply #11 on: July 21, 2019, 09:21:26 AM »
@GeneWengert-WoodDoc I cannot believe you did not get the skinny on the entire schedule.   :).  good to know it can be done.  how big were the discs.
« Reply #12 on: July 21, 2019, 07:35:43 PM »
The slightly oval disks we had were about 12 x 18.  They were dry and sanded smooth with bark on.
Offline WDH
  • April 1998 - August 2008
    • hamsleyhardwood.com
« Reply #13 on: July 22, 2019, 08:08:00 AM »
I looked them up and noticed that they cut them thin.
Woodmizer LT40HDD35, John Deere 2155, Kubota M5-111, Nyle L53 Dehumidification Kiln, and a passion for all things with leafs, twigs, and bark.  hamsleyhardwood.com
drying cookies and blanks
Started by shampjm1 on Sawmills and Milling
Last post June 12, 2020, 08:05:32 AM
by WDH
kiln drying cedar cookies
Started by xlogger on Drying and Processing
Last post March 31, 2021, 05:14:11 AM
by xlogger
Drying cookies and log slices without cracking.
Started by Joe Hillmann on Drying and Processing
Last post March 25, 2015, 07:38:44 AM
by grweldon
drying cross section cookies ?
Started by Daren on Drying and Processing
Last post April 16, 2007, 11:23:18 AM
by Ironwood
