Author Topic: Roundover bit screw marking wood  (Read 715 times)
Offline Brad_bb
« on: August 11, 2019, 11:35:21 PM »
So I'm making these dutchmans to fit in some floor joist mortises.  (the floor of the loft was lowered leaving these original mortises exposed- the joists were removed and moved down to the new beams.  So as a decorative dutchman, I'm making these.  The pattern reflects the tile being used elsewhere in the building.
So the problem is that I routered the cross out using a guide bushing and a template I made.  then I wanted to put an 1/8th inch roundover on top of it, which I did, but didn't notice that the screw for the guide bearing was touching the floor and marking it.  The height of the cross is 9/16".
So is there any common solution to do the 1/8" roundover when the height is limited?  Is there a lower profile screw?  Or a guide pin instead of the beaing with the screw?
Offline low_48
Re: Roundover bit screw marking wood
« Reply #1 on: August 12, 2019, 12:04:48 AM »
Just grind a little off the end of the bolt. You can use a vise-grips to remove the bolt latter if you want to.
Offline Old Greenhorn
    • Woodsman Forest Products
« Reply #2 on: August 12, 2019, 06:59:02 AM »
Is that a socket head cap screw on there Brad? You can swap it out for a button head and it should be just fine.
Oscar 328 Band Mill, Husky 450, 372 (Clone), Mule 3010, and too many hand tools. :) Retired and trying to make a living to stay that way. NYLT Certified.
OK, maybe I am the woodcutter now.
I can work with wood, but I am NOT a Woodworker, yet.
Offline 21incher
« Reply #3 on: August 12, 2019, 12:24:03 PM »
I use the brass piloted bits from MLCS.  They hang down about the same as a bearing but you may be able to grind some off.
Hudson HFE-21 on a custom trailer, Deere 4100, Kubota BX 2360, Echo CS590 & CS310, home built wood splitter, home built log arch, and a logrite cant hook.
Offline doc henderson
« Reply #4 on: August 12, 2019, 12:35:38 PM »
if you dispense with the bearing and use a solid guide you may get burning or marking of the other contour.  I love my 1/8th inch round over even for rustic.  "elegant" rustic so people do not injury themselves.  the bits also have trouble if the guide surface is undermined like a thinner edge of live edge slab and then we will see a mark from the washer.  how about a thinner "low profile" bearing. not sure they exist.
Offline 21incher
« Reply #5 on: August 12, 2019, 04:02:59 PM »
I have not had a issue with burning. The brass bushing is only 3/16 in diameter so the whole bit is smaller resulting in a slower surface speed of both the cutting and bushing. Just don't stop in one place.
Another option may be to attach the bearing to the bit permanently with loctite permanent bearing locker ( the green stuff ) just to make a dedicated bit.
Offline Bruno of NH
« Reply #6 on: August 13, 2019, 04:19:30 PM »
Would a router table work
With the bit 21 has spoken about?
Offline 21incher
« Reply #7 on: August 13, 2019, 07:40:18 PM »
These are the ones I have used https://www.infinitytools.com/brass-pilot-router-bits-1 and they can be used in a table.
Offline curved-wood
« Reply #8 on: August 13, 2019, 07:43:27 PM »
Sometimes I use my old 40 years pin router bit when the dimensions are too tight. Sometimes that small difference is enough to get the job done since there is no bearing at the end. Since it is hard steel and not carbide, I am able to sharpen them with a diamond file. I try not to stop because it will burn the wood easily ( I guess that is the idea of the bearing)
Offline Brad_bb
« Reply #9 on: August 13, 2019, 08:44:51 PM »
Just ordered a set.  Thanks.
Offline 21incher
« Reply #10 on: August 14, 2019, 06:12:36 PM »
I'm jealous you are getting the whole set. I only have the 1/8 radius. Started with a MLCS one but that didn't stay sharp very long. The infinity one seems to be made of better carbide  and stays sharp.  If you have a lot of them to make you may find it's not too expensive to have someone with a CNC router  crank them out.
Offline Brad_bb
« Reply #11 on: August 14, 2019, 06:44:23 PM »
5 more to make.  Originally I was trying to find someone with a CNC.  I wasn't having any luck, but then I realized that I could just do it with a router and template.  Yes it takes a lot longer and you eat a lot more walnut saw dust.
Low Cost Chinese Laser Engraver For Marking Wood Projects
Started by 21incher on General Woodworking
Last post September 28, 2021, 07:58:16 PM
by Stephen1
Oil screw
Started by minesmoria on Chainsaws
Last post October 28, 2004, 02:36:54 AM
by jokers
When you screw-up, what do you do?
Started by D._Frederick on Sawmills and Milling
Last post October 10, 2003, 09:26:14 PM
by Percy
Screw Pie . . . . . .
Started by TexasTimbers on General Board
Last post December 09, 2006, 04:14:36 PM
by woodmills1
