Author Topic: Making shiplap.  (Read 695 times)
Offline Dave Shepard
  • Geometrically proportional
    • My homepage
Making shiplap.
« on: April 28, 2021, 01:36:26 PM »
I've got a bunch of shiplap to make. I'm curious how people are making it. I have a tablesaw and a Festool track saw. I don't know if it would be easier to buy a dado set for the table saw, or a router for the Festool track. I'll be making it from 1" white pine.
Offline alan gage
Re: Making shiplap.
« Reply #1 on: April 28, 2021, 02:17:40 PM »
I have a powerfeeder so I'd make it on the table saw with dado blade. Probably would even if I didn't have the powerfeeder
Depending how deep the grooves need to be I don't know if the router could make the cut in one pass or not, which would slow down the whole process. If you could do it in one pass it would go pretty quick. If you can find a suitable bearing guided cutter you wouldn't even need the track.
Not sure how much cutting you do on the table saw but owning a power feeder for 6 months I sure have found it to be handy. I don't use it all that often but when I do it's great. Not only is it faster and less tiring but it holds the board flat to the table and gives cleaner, more consistent cuts. Keeps my hands away too. Might be worth looking into.
Alan
Timberking B-16, a few chainsaws from small to large, and a Bobcat 873 Skidloader.
Offline newoodguy78
Re: Making shiplap.
« Reply #2 on: April 28, 2021, 02:28:00 PM »
Iíve done it with a router and table saw quite a bit for any quantity I much prefer the table saw. I always make up some feather boards, one pushing down and one towards the fence.
Offline Southside
    • White Oak Meadows
Re: Making shiplap.
« Reply #3 on: April 28, 2021, 06:05:50 PM »
Anyone around have a moulder you could hire to do it? We make a pile of it.
White Oak Meadows
    • My homepage
Re: Making shiplap.
« Reply #4 on: April 28, 2021, 08:55:06 PM »
I just need to make small batches for different projects. Not enough to justify hiring it. There is a very good milkwork shop nearby for bigger runs.
Offline firefighter ontheside
  • I like trees.
Re: Making shiplap.
« Reply #5 on: April 29, 2021, 08:26:56 AM »
I made shiplap out of treated 5/4 x 6 deck boards using just a handheld router and a rabbeting bit with a bearing.  It worked fine.  If I was making it with nicer wood, I would do it on my tablesaw with dado as Alan suggested.  I think it would be much faster than the handheld router and probably safer in the long run.
Woodmizer LT15
Kubota Grand L4200
Stihl 025 and MS291
2017 F350 Diesel 4WD
Kawasaki Mule 4010
Offline tmbrcruiser
Re: Making shiplap.
« Reply #6 on: April 29, 2021, 08:33:28 AM »
I make ship lap from time to time and use a five spindle moulder most of the time. But when I'm asked for random width that doesn't work. The first thing if not using a moulder, the lumber needs to be straight lined and at least one side planned so that all of the lumber is the same thickness. After that I run it on a spindle shaper with power feed. What works for me may not work for you, good luck finding the easy path.
Once you get sap in your veins, you will always have sawdust in your pockets.
    • My homepage
Re: Making shiplap.
« Reply #7 on: April 29, 2021, 10:49:58 AM »
Thank you for all the replies. I'm making random width, just as it comes off the mill. I can straight line with the Festool first.
Offline scsmith42
    • Whispering Pines Farm
Re: Making shiplap.
« Reply #8 on: April 29, 2021, 09:31:10 PM »
Dave, normally I make shiplap in the moulder but have also used both a shaper as well as a tablesaw with a dado blade to make it.  Both the shaper and the tablesaw have power feeders, which really helps to simplify the process.
When I use the tablesaw I have a sacrificial fence that clamps to the tablesaw fence so that I don't have to move the fence.  This also keeps the blades a safe distance away from the tablesaw fence.
Let me know if you want some pix.
Scott
Tom's 3638D Baker band mill
    • My homepage
Re: Making shiplap.
« Reply #9 on: April 29, 2021, 09:40:10 PM »
I can visualize what you are saying. Thanks.
Offline Trackerbuddy
Re: Making shiplap.
« Reply #10 on: April 30, 2021, 12:36:47 PM »
Do you want to listen to a router for hours on end?
Offline Bruno of NH
Re: Making shiplap.
« Reply #11 on: May 01, 2021, 11:09:57 AM »
Dave,
I have run a bit one time with a hand held router.
3 1/2 it worked well.
But a molder or table saw/shaper with power feed would be quicker.
Making/Applying Shiplap...Update
Started by tcsmpsi on General Board
Last post November 01, 2012, 09:29:10 AM
by routestep
question
Shiplap
Started by Bandit on General Woodworking
Last post April 29, 2007, 05:45:52 PM
by Ianab
CSM: Shiplap - Rough Cut
Started by Lost in the Outback on Sawmills and Milling
Last post April 19, 2013, 07:59:18 PM
by losttheplot
miles of shiplap
Started by hackberry jake on General Woodworking
Last post October 16, 2016, 08:02:26 AM
by Just Me
