Author Topic: Timber frame peg removal  (Read 297 times)
Offline Jayjay
« on: May 08, 2021, 01:28:14 PM »
Hi guys
Completely new to timber frame. Carpenter for 30 years so I know a little.
Any other ideas on removing pegs from 150 year old house. Tried everything. Bent my 4í bar trying.
Any ideas begfore I give up and drill it out. ?
Offline moosehunter
  • Every once in a while
    • Saw it Coming
Re: Timber frame peg removal
« Reply #1 on: May 08, 2021, 01:44:33 PM »
You should post this in the timber frame log home section.
mh
Higher than my expectations
Offline Don P
    • Calculator Index
« Reply #2 on: May 08, 2021, 05:43:34 PM »
Do you understand drawboring, which was likely done to assemble the frame?
The path the pegs follow is probably not a straight line but set up with the holes slightly offset to "draw" the joint tighter as the tapered peg is driven home. The pegs were likely dry and installed into green timber which has bitten into them as it seasoned, and then over the years as the building has experienced loads there is likely some shearing of the pegs and interscting faces of the joints, binding them tighter. If you've seen double shear diagrams, that's what you probably have.
All that to say, drill them out with a slightly undersized bit, preferably drilling in from each side through the mortise cheeks but not into the offset hole in the tenon. Then sneak up on the edges with a smaller forstner bit or try to collapse the peg wood into the drilled hole.
The future is a foreign country, they will do things differently there - Simon Winchester
Offline Jayjay
« Reply #3 on: May 12, 2021, 05:57:38 PM »
I think Iím in over my head. Again.
Offline Don P
    • Calculator Index
« Reply #4 on: May 12, 2021, 06:43:41 PM »
"Ain't scared" gets me in more trouble  :D
Online Tom King
    • HistoricHousePreservation
« Reply #5 on: June 21, 2021, 06:55:50 PM »
I had missed this, earlier.
For pegs you can't get to the back of, I use a slide hammer.  For autobody work, they come in a kit with all sorts of things to put on the ends.
  I have a couple of picture of me pulling some small, 1/2" pegs, but it works the same for large pegs.  It works the same way.  You just have to use progressively larger eye screws as the pegs get bigger.
Offline Jim_Rogers
  • Board Moderator
  • Keep your chisels sharp.
    • jrsawmill.com
« Reply #6 on: June 21, 2021, 10:13:01 PM »
Once the peg is out of the timber a little, it may split from the screw pulling it out. To prevent that from happening, put a hose clamp around the peg and it will hold it together.
works for me.
Jim Rogers
10' X 12' Timber Frame Shed (Raising the Frame)
Started by jander3 on Timber Framing/Log construction
Last post September 05, 2021, 12:35:51 PM
by ljohnsaw
Post and Beam/ Timber frame Cabin Questions- New to timber framing
Started by TimberHawg1 on Timber Framing/Log construction
Last post February 15, 2019, 02:01:04 AM
by D L Bahler
Timber size calculator and timber frame design.
Started by Joe Vachon on Timber Framing/Log construction
Last post July 07, 2017, 10:25:46 PM
by Roger Nair
Timber Removal - East Texas
Started by GraceNmercy on Forestry and Logging
Last post October 16, 2015, 10:18:48 PM
by stpestan10
