Author Topic: End Grain tearing  (Read 488 times)
Offline batesvillebuck
End Grain tearing
« on: June 15, 2021, 11:54:14 AM »
Hello, just recently started doing some small mugs, etc on a lathe.  Having a lot of trouble with end grain tearing out on some of the different species.  Any tricks to keep this from happening?
Online btulloh
Re: End Grain tearing
« Reply #1 on: June 15, 2021, 01:27:19 PM »
Razor sharp tools help. A power strop for the final step.
With that piece on the left end the grain orientation guarantees tear out thought. In a piece like your mug theres so many grain variations that itll be a fight all the way to the finish line. Higher speeds and sharp edges can help. I hate to use sandpaper but that may the only way to cleanup at the end. Then buff.
Nice looking piece. Lot of end grain there to fight with!
HM126
Offline Larry
    • Copas Sawmill
« Reply #2 on: June 15, 2021, 08:48:53 PM »
When I turn, every cut I make is a practice cut for my final cut.  By that I mean as soon as I get the project round I try a cut to see how clean it is.  So, if I was using a bowl gouge on your project I would try a push cut, than a shear slicing cut, and finally a shear scraping cut.  If one was better than the rest that would be the cut I used near the end.  If none of the cuts were good I might switch to a spindle gouge and see what that does.
Sometimes none of the cuts work, especially in punky wood.  Than you can try to stiffen the fibers.  I normally do that with sanding sealer but you can also use thined lacquer wiped on, or even ca glue.
Offline low_48
« Reply #3 on: June 16, 2021, 12:42:00 AM »
What tool are you using?
Offline ron barnes
« Reply #4 on: June 16, 2021, 08:08:58 AM »
As stated above, sharp tools,  higher speed and sandpaper as required.
« Reply #5 on: June 23, 2021, 08:17:40 AM »
low_48, I am using Simple Woodturning Tools (all new, full size carbide insert tools): simple roughing tool to get it round, then simple turning & hollowing tool to get to finished size.
Tearing Stuff Up
Started by metalspinner on General Board
Last post May 10, 2021, 10:25:43 AM
by mike_belben
Tearing Down the House
Started by DR_Buck on General Board
Last post March 31, 2018, 09:28:06 AM
by Randy88
face grain vs end grain drying rates
Started by kelLOGg on Drying and Processing
Last post January 24, 2019, 07:50:58 PM
by Don P
Tearing Down an Old Barn -For salvage Timber
Started by D L Bahler on Timber Framing/Log construction
Last post December 04, 2013, 01:24:11 PM
by D L Bahler
