Author Topic: Chestnut oak table top  (Read 890 times)
Offline Greyhound
« on: June 17, 2021, 05:47:42 PM »
Here's a sneak peak at a table top I'm working on after a first coat of Waterlox.  The lumber came from the "leftovers" from some chestnut oaks I had milled a while ago.  I sold off all the primo clear and quartersawn lumber from that whack.  I have several dozen more dead standing chestnut oaks on my property.  I look forward to felling and milling them in the near future.  Much better than using them for firewood.
Offline Greyhound
Re: Chestnut oak table top
« Reply #1 on: June 20, 2021, 10:36:42 AM »
Here's the base with it's first coat of finish.
Online trimguy
« Reply #2 on: June 20, 2021, 10:46:17 AM »
Very nice! Curious, whats the groove around the inside for ? Some way to attach the top ?
Offline Dan_Shade
  • I don't want to edit my profile!
    • Shade Custom Sawing
« Reply #3 on: June 20, 2021, 11:36:02 AM »
Very nice.  I have a coffee table that I made from chestnut oak.
One of my favorite woods.
lots of dull bands and chains
Online btulloh
« Reply #4 on: June 20, 2021, 01:23:22 PM »
That groove is for standard clips made specifically for table tops. They screw to the underside of the top and the other end is offset and goes in the groove. Easy way to accommodate seasonal wood movement in a table top. They are readily available and in pretty wide use.  Z clips
Theres also a figure 8 type clip thats pretty popular but they dont use a groove, just a shallow counterbore with a forstner bit.
HM126
Online trimguy
« Reply #5 on: June 20, 2021, 08:03:56 PM »
Thanks for the link.
Offline KenMac
  • I'm new, but don't feel so new!
« Reply #6 on: June 20, 2021, 08:26:09 PM »
Very nice work Greyhound!! I like the character imperfect wood gives a piece.
Cook's AC3667t, Cat Claw sharpener, Dual tooth setter, and Band Roller, Kubota B26 TLB
Offline WDH
  • April 1998 - August 2008
    • hamsleyhardwood.com
« Reply #7 on: June 21, 2021, 07:41:28 AM »
Beautiful table.  Nice job on the breadboard.  Is it tongue and grooved and pinned?
Woodmizer LT40HDD35, John Deere 2155, Kubota M5-111, Nyle L53 Dehumidification Kiln, and a passion for all things with leafs, twigs, and bark.  hamsleyhardwood.com
Offline Greyhound
« Reply #8 on: June 21, 2021, 03:08:20 PM »
As above for clips hold the table top to the base and allow plenty of movement. They are quick, easy and work great.
Online Ianab
« Reply #9 on: June 21, 2021, 08:18:46 PM »
You can also make wooden "buttons" that work the same as the Z clips.Same idea, holds the table top in place but allows for some wood movement.
Offline samandothers
« Reply #10 on: June 21, 2021, 10:22:57 PM »
Do you use Waterlox a lot for your furniture?  I have used it on some smaller pieces.  It  seems pretty easy to use, it does leave a bit of an amber tone it seems on some of the items I've done.
Offline Greyhound
« Reply #11 on: June 22, 2021, 09:21:45 PM »
Yes, it has a little amber tone.  Looks really good on this oak.  I've used it on a couple table tops before but those were closed grain cherry or maple.  This is my first time using it on oak. It's super waterproof but doesn't have the same "build" as polyurethane... I tried something new (recommended on the waterlox site) and wet sanded the first couple coats to try to fill some of the pores with slurry.  We'll see how it turns out eventually.
Offline WDH
« Reply #12 on: June 23, 2021, 06:49:46 AM »
Wet sanding when using pure tung oil works great to fill pores and get a glass smooth finish too.
Offline Greyhound
« Reply #13 on: June 25, 2021, 07:49:11 PM »
Yes it is.
Offline Greyhound
« Reply #14 on: June 25, 2021, 07:52:00 PM »
Here's the final product delivered to FIL's place.  Also included a picture of the underside with the clips.
« Reply #15 on: June 25, 2021, 10:57:33 PM »
Very elegant!  Did the wet sanding help smooth the finish?
Offline Greyhound
« Reply #16 on: June 28, 2021, 12:39:41 PM »
Yes.  I wasn't going for a completely flat surface, but it did even out quite a bit.  You can see the difference in the texture of the top and bottom.  No wet sand on bottom.
chestnut oak coffee table
Started by Dan_Shade on General Woodworking
Last post February 06, 2013, 08:52:18 AM
by Lud
American chestnut lumber vs chinese chestnut lumber
Started by Weekend_Sawyer on Tree, Plant and Wood I.D.
Last post March 20, 2017, 08:50:53 AM
by Weekend_Sawyer
Is anyone concerned about weight with large Harvest table/threshers table
Started by Leegej on General Woodworking
Last post April 11, 2017, 09:41:32 AM
by Leegej
Turning Table..or ...Table's Turned??
Started by Burlkraft on General Board
Last post May 12, 2006, 06:10:32 PM
by DoubleD
