Author Topic: Reference Faces For centered Brace  (Read 238 times)
Offline AKsteelhead
« on: July 29, 2021, 01:38:41 PM »
Hello All,
First question on forum. Been learning from you all for a couple of years now and thank you for all the information that so many of you have provided. I have been apart of a few small frame builds and everything I know has come from these pages. I have for the most part been able to find answers to my questions on here. My question today is about doing centered braces with 1/2" deep pockets. I know the concern about being able to accurately measure the pocket depth on rough cut timbers has come up because these pockets are on none reference faces. I am going to build a four post frame for a house entrance, picture is below. Normally using square rule the two outside faces of each corner post would be my reference faces. On this frame could I do just the opposite and have the two inside faces of each post be my reference faces. By doing this my pockets would be a true 1/2" deep and plumb/square with the other reference face that also has a brace pocket. The only draw back I can see from doing this is my exterior outside faces of posts and plates might not be flush to each other. There might be a little "lip" where two members meet if they are not exactly 8" dimension. To stay uniform I guess I would have to use the inside faces of the ties and plates as reference faces too. I wont be putting siding on this frame and could touch up those little lips on the outside if needed. Any info would be much appreciated.
Offline flyingparks
  • If my dog doesn't like you, I don't like you.
Re: Reference Faces For centered Brace
« Reply #1 on: July 29, 2021, 09:00:19 PM »
If you use the same reference face for your braces, that you use for your posts and beams, then you should be fine. Whether it's outside or inside.
Reference faces vs. centerlines
Started by pizza on Timber Framing/Log construction
Last post October 24, 2019, 08:33:09 AM
by pizza
Understanding and using reference faces of timbers in timber framing videos
Started by Jim_Rogers on Timber Framing/Log construction
Last post April 18, 2019, 09:41:21 PM
by timberframe
How to cut a centered brace pocket?
Started by jander3 on Timber Framing/Log construction
Last post February 23, 2015, 07:42:56 PM
by jander3
Face centered vs. log centered pith - revisited
Started by kelLOGg on Sawmills and Milling
Last post August 13, 2016, 12:20:01 AM
by Rougespear
