Author Topic: sycamore is down!!  (Read 4206 times)
Offline bad_boards
sycamore is down!!
« on: August 24, 2006, 10:15:19 AM »
http://mikelcumiskey.spaces.live.com/
hope that link is ok to post
i tried to add pics here and guess y`all are just way way smarter
i couldnt get it done
well the sycamore pics are on the that site, on the right
be well
mikel c
Offline beenthere
Re: sycamore is down!!
« Reply #1 on: August 24, 2006, 10:21:03 AM »
Not smarter. Just followed the directions. Most of us had the same initial frustration, and now wonder what the fuss was all about.  ::)
But like a lot of these computer things, one doesn't know how close or far away one is from a solution.
Resize to 400 pixels first, and after that, save to lowest compression. Works every time (for me).  :)
Offline DanG
« Reply #2 on: August 24, 2006, 10:35:29 AM »
Mikel, let me know where you're getting jammed up and I'll help ya through it.  It's fun to see your pics show up on the forum.
Offline bad_boards
« Reply #3 on: August 24, 2006, 11:10:24 AM »
think i got it now
Offline pigman
« Reply #4 on: August 24, 2006, 12:04:30 PM »
Good job bad_boards on the sycamore and the pictures.  8) If you don't compress   as much, the picture will be a little bit clearer. Your pics are about 7k bytes. If you leave them about 12 or 15 k they will still download fairly fast for us with slow dial up and be a little sharper. You are the first person I have suggested to increase the file size. ;)
Bob
Offline bad_boards
« Reply #5 on: August 24, 2006, 12:18:49 PM »
dont think i`l be going overboard on posting pics, whew wee what a pain
but i got it done
Offline DanG
« Reply #6 on: August 24, 2006, 12:41:09 PM »
Aww, it ain't no pain at all, Mikel. :D :D  Leastways, once ya get used to it.  Now that you've done it, it'll seem a lot easier next time.  One of the tricks I've learned is to stand further back when taking the pic, so there is a lot of background to crop out.  Sometimes, cropping and resizing is enough to reduce it to Forum specs.  Another handy thing, when you rename the file, use a low alpha character such as A or B in the new title.   That way, it will be first up in the album when you reopen it.  I always close and reopen the pic in xat after each step.  Trust me, it's easier that way. ;)
Example:  old name- sycamore1
                 new name- asycamore1
Offline bad_boards
« Reply #7 on: August 24, 2006, 01:01:24 PM »
ok, seems that after i fuss with it and get it to load up
that its blurry and not crisp at all
i wanted to post a pic showing the way tight grain and there is noway
its a just a brown mess.
main reason i wanted them up was getover it is going to bring his swinger dwn
to cut up the 2 major logs, wanted him to see whats what b4 he drives dwn
Offline mike_van
« Reply #8 on: August 24, 2006, 02:15:14 PM »
The logs a brown mess, but the pup looks good -  :D
Offline beenthere
« Reply #9 on: August 24, 2006, 02:16:57 PM »
I'll try this for the third time - lightning/thunderstorm bleeped me off twice in the middle of it.......
I downloaded one of your sycamore pics, and resized it to 400 pixels, then saved. It turned out such;
Then I cropped the original to take out some background, and resized it to 400, then saved it to lowest compression. It turned out such;
Hope this helps along with DanG's help and your persistence. Should get some good boards from that tree.
Offline Stephen1
  • Where there is a will, there is a way!
    • muskoka Sawmill
« Reply #10 on: August 24, 2006, 02:54:30 PM »
don't give up bad_boards itl come to you.I had a heck of a time at 1st and still get the odd picture bounced. But we do like pictures! thoselogs will give you some good_boards
Offline getoverit
  • freeing trees from silence
« Reply #11 on: August 24, 2006, 07:12:10 PM »
Looks like ya got the pic posting figured out :)
The Peterson ATS should go through those like butter... soon as it cools off a bit we can get them milled  for ya !
Offline bad_boards
« Reply #12 on: August 25, 2006, 08:06:38 AM »
sounds wonderful getoverit.
i did get 1 five footer on the hudson and too the top off it, just to take  a looksee
the dern sapwood looks nice.  overnite it turned a nice copper color with streaks in it
y`all be well, happy milling!!!!
mikel
Offline bad_boards
Re: sycamore is down!! think i got this wired
« Reply #13 on: August 25, 2006, 09:15:41 AM »
Offline bad_boards
« Reply #14 on: August 25, 2006, 09:30:16 AM »
Offline timcosby
  • I'm new! or is it green
    • my blogs
« Reply #15 on: August 25, 2006, 02:02:05 PM »
dats nice lookin wood there now!!!! :o
how does sycamore dry??? easy hard??
Offline bad_boards
« Reply #16 on: August 25, 2006, 02:25:18 PM »
dunno , but sure going to find out
got a ton of it
« Reply #17 on: August 25, 2006, 02:31:32 PM »
You'll be happier with it at 5/4 rather than 4/4.
It doesn't do well when left to the elements.  Dry in a breezy, semi-enclosed, sheltered area.
Offline bad_boards
« Reply #18 on: August 25, 2006, 02:38:11 PM »
5/4 processed to   7/8th ? 3/4?   is this due to twist or cupping?
tell me it dont dry like sweetgum , please
« Reply #19 on: August 25, 2006, 02:41:48 PM »
It is rather difficult and care must be taken in sawing to keep the grain as straight as possible.  I dry both sycamore and sweet gum in a pole barn and keeping them out of the elements helps both considerably.
Hey.. where'd my sycamore go?
Started by mrector on Sawmills and Milling
Last post September 21, 2014, 12:27:11 AM
by SAnVA
Sycamore
Started by Ludo on Sawmills and Milling
Last post March 31, 2013, 10:25:15 AM
by Old Wood Whacker
Using sycamore for B&B
Started by Qweaver on General Board
Last post January 13, 2016, 08:29:22 AM
by Brad_bb
Sycamore
Started by WV Sawmiller on Sawmills and Milling
Last post January 07, 2016, 10:55:26 AM
by Dodgy Loner
