source for 14" single grouser pads
Started by OneWithWood, May 01, 2007, 10:21:00 AM
OneWithWood
When I replaced my JD450C crawler loader I let the grouser pads go with the old machine.  That was a mistake.  The three bar pads on the replacement machine are extremely limiting on the steep terrain that is my woods.  I desperatley want to replace the three bar pads with single grouser pads.  The problem I am having is that these machines don't get used much for logging today so the bulk of available grouser pads are for dozers.  A dozer pad is 18+" while a loader pad is only 14".
I have searched the web but I have not located a source for the 14" pads.  My JD dealer is also searching.
Any ideas?  If I could find used pads that would be great becasue I am sure new ones are salty.
One With Wood
Steven A.
Try these guys. A large used heavy equipment dismantler in Wisconsin. They have new aftermarket parts as well.   http://www.thilltractor.com/
Have you thought of buying replacement grouser bars and welding them on?
Corley5
Fla._Deadheader
 In Arkansas, I watched guys welding on "Toe Steel". They bought boxes of bars specially made for welding onto worn down ribs on the pads. I KNOW they used 14" on one dozer. I owned that one for a while ???
OneWithWood
Steve, actually I have thought of welding bars on.  My thought was to weld  ¼"x1" flat stock onto the center bar of the triple bar.  Do you think that would work?
When I find out the cost of new pads I may opt to do the welding.
Corley that would be a lot of cutting  :-\  I am lazy by nature  ;)
One With Wood
Fla._Deadheader
Can't imagine using ¼" for cleats.  ??? ???  ½" would be minimal and it's HARD stuff.
OneWithWood
I will have to source that 'toe steel'.  Do you think it would function ok welded to the center bar of the three bar 'street pads'?
One With Wood
Corley5
It'd be a lot of welding  :)  Bet ya could burn two inches off the ends of each one faster than you could weld bars on to them  ;D
OneWithWood
You got a point.  I probably should aquire a torch if I am going to change out pads.  I am sure it would make removing the bolts a bunch easier.  Yeah, I need a torch.
So that brings up another question.  What do I need to know about torches?
One With Wood
logwalker
Use this as a good excuse to buy a plasma cutter and trim those with no muss and very little fuss. I am looking for an excuse to buy one. Joe
bioguy
Have you tried CrawlerHeaven? I got a half dozen grouser plates for my old T340 crawler/loader from him. He usually has a bunch of machines in the process of parting out.
Dave
bioguy
scsmith42
OWW - why not just run 18" pads?  You'll have lower ground pressure, and I'm pretty sure that the UC is the same on a 450C - whether it's a dozer or a loader.
If you torch them, get a plasma cutter - hands down the trick way to do it.
Find out who your local Berco dealer is.  I can provide you with a local reference that has great prices and customer service, and they can ship them to you.  Let me know if you're interested.
Scott
Tom's 3638D Baker band mill
gmmills
      What you are looking for is what is termed weld on grouser stock. Your JD dealer should be able to find it for you.  You will want to weld the grouser stock to the front bar of the pad. The same position as a standard single bar grouser.
    There are alot of older 450C's still in the woods in my area. The last set of pads that I put on my old machine were 14 inch triple grousers with welded on bar stock. I have also seen guys use 18inch single grouser pads and burn 2 inches from the inside for boom clearance. This gives you a 16 inch offset pad. Less ground pressure equals more floatation.  The only drawback to this is the rollers and track chain tend to wear more unevenly. More stress on the outside edge of the track.
    We used to be able to buy single grouser pads with the option of an open center pad or closed center pad. I think only closed center pads are availiable today.
     I have two left over triple grouser pads, like new, one with the gouser bar all ready welded on it. They both need a home, since I sold my 450C loader 5 yrs ago. If you interested PM me.
scsmith42
        You can't run 18" pads on a 450C loader. No boom clearance.
Custom sawing full-time since 2000.
WM LT70D62 Remote with Accuset
Sawing since 1995
scsmith42
GM - thanks for the info.  I spent some time on a 450B loader - but that was 25 years ago, and in my fuzzy memory the UC seemed similar to my current 550B.
Scott
