Author Topic: Search Index  (Read 3716 times)
Offline Jeff
  • Fearless Leader
  • Oh la di oh la da
    • Behind the  Forestry Forum YouTube channel
Search Index
« on: December 03, 2007, 02:43:14 PM »
For the next hour you "might" experience some slowness with the server as I work to ultimately speed it up.  Right now when someone searches the forum, it takes the resources of the forums database to create the results. To many searches can drag the forum's response time.
I am currently creating a search index that is separate from the database. Searches performed once the index is created will search the index, not the database, Those searches will have no effect on the forum resources as it does now.  I am currently about 6% into this. It should be completed within an hour.
Offline thecfarm
Re: Search Index
« Reply #1 on: December 03, 2007, 04:34:11 PM »
Thank you jeff.You really help people out that just have dail up.I really appreacate it.
Offline Jeff
  • Fearless Leader
  • Oh la di oh la da
Re: Search Index
« Reply #2 on: December 03, 2007, 04:38:06 PM »
This is taking considerably longer then I planned. I am at only 25%
Oh Well. :)
Offline Jeff
  • Fearless Leader
  • Oh la di oh la da
Re: Search Index
« Reply #3 on: December 04, 2007, 08:21:18 AM »
The search indexing seems to be a success.  :)
Offline Jeff
  • Fearless Leader
  • Oh la di oh la da
Re: Search Index
« Reply #4 on: December 04, 2007, 08:28:55 AM »
Searching seems to be almost instantaneous, at least from here.  IT turns out that it took me a little over 11 hours instead of 1 so I was only a little off. :-\ :)
Offline Norm
Re: Search Index
« Reply #5 on: December 07, 2007, 07:58:27 AM »
I wonder if the search function is what was causing some timeouts. Since you've redone it I get almost none of them. Of course this is cutting into coffee and bathroom breaks for me. ;D
Offline Jeff
  • Fearless Leader
  • Oh la di oh la da
Re: Search Index
« Reply #6 on: December 07, 2007, 09:00:18 AM »
It could have been part of it.  Searching the forum took a lot of resources. I'm thinking I still have a database issue yet to clear up before some of those little time outs go completely away.
Offline Jeff
  • Fearless Leader
  • Oh la di oh la da
Re: Search Index
« Reply #7 on: December 18, 2007, 04:13:13 PM »
I am updating our search index. searches for the next couple hours will most likely fail until this is completed.
Offline Jeff
  • Fearless Leader
  • Oh la di oh la da
Re: Search Index
« Reply #8 on: January 08, 2008, 11:41:54 PM »
I'll be updating our search index tonight. Attempted searches may be slow or timeout until morning.
Offline Jeff
  • Fearless Leader
  • Oh la di oh la da
Re: Search Index
« Reply #9 on: January 09, 2008, 11:01:33 AM »
This was interrupted during the night so it continues....  Searching the forum will be slow yet for the morning.
Re: Search Index
« Reply #10 on: January 09, 2008, 05:41:17 PM »
Database Error: Lost connection to MySQL server during query
File: /home/www/forestryforum/board/Sources/MessageIndex.php
Line: 606Database Error: Can't connect to local MySQL server through socket '/tmp/mysql.sock' (111)
File: /home/www/forestryforum/board/Sources/Load.php
Line: 2020
Offline Jeff
  • Fearless Leader
  • Oh la di oh la da
Re: Search Index
« Reply #11 on: January 09, 2008, 05:46:14 PM »
I was rebooting the mysql server
Re: Search Index
« Reply #12 on: January 09, 2008, 05:50:09 PM »
well, kick it again while it's down.
Offline Jeff
  • Fearless Leader
  • Oh la di oh la da
Re: Search Index
« Reply #13 on: January 09, 2008, 05:50:53 PM »
I'm doing just that.
Offline Furby
  • Blurb....
Re: Search Index
« Reply #14 on: January 09, 2008, 06:53:19 PM »
Fight, fight, fight!
Offline Jeff
  • Fearless Leader
  • Oh la di oh la da
Re: Search Index
« Reply #15 on: February 26, 2008, 09:22:49 AM »
I'll be updating the search index throughout the day to day, so searching the forum could prove to be problematic. It'll get good again when I am finished. :)
Offline Jeff
  • Fearless Leader
  • Oh la di oh la da
Re: Search Index
« Reply #16 on: March 16, 2008, 08:42:01 AM »
With the time outs and things going on the last few weeks I had been unable to successfully create an updated search index for the Forestry forum. Searches had been slow and adding to the problems on the forum.  It appears I might have a few things sorted out as last night I was finally able to work on the index again and complete it, and enable it.
Searches should be very fast now.
Offline StorminN
Re: Search Index
« Reply #17 on: March 16, 2008, 12:28:27 PM »
WHOA!! That's a HUGE difference! Great job!
 8) 8) 8) 8) 8) 8) 8) 8) 8) 8)
I had been having trouble getting the search to even work, and had noticed if I was specific with naming just one forum, it would work, but now this is great!!
-N.
Happiness... is a sharp saw.
Testing something on the forum index
Last post September 16, 2014, 12:53:11 PM
by drobertson
Site index confusion
Started by jeffreythree on Ask The Forester
Last post May 10, 2009, 11:22:50 AM
by woodtroll
Beware of Sasafrass sawdust(105 heat index)
Started by drobertson on The Outdoor Board
Last post July 09, 2013, 11:58:06 PM
by justallan1
The search for my Saw
Started by GoStumpy on General Board
Last post February 23, 2013, 08:47:40 PM
by Sonofman
