Author Topic: Need Sharpening Service in/near CT  (Read 9023 times)
Offline taw6243
    • Silverwood Sawmill
Re: Need Sharpening Service in/near CT
« Reply #20 on: May 04, 2019, 09:44:24 PM »
That is pretty messed up if at their whim they decide to change a profile then we canít resharpen a resharped blade from woodmizer like I used to unless I buy their newly changed 4 degree  profile. Sounds like job protectionism from Woodmizer. I have noticed attitude changes at Woodmizer since the company went to employee owned ( sort of like when consumers power company I worked for for 16 years changed to consumers energy it became What is referred to as a corporate mentality. Less of an inclusive family atmosphere and a sort of hardening of the heart type of thing)
4500 hours on my 2004 LT40HDG28, CBN sharpener and auto setter, 25" woodmaster planer with 9'auto leveling bed and trac vac chip handling system, 1998 L3010 kubota, 2010 L3200 kubota Festool TS75 rail saw with 42", 75" and 106" rails.
Offline taw6243
« Reply #21 on: May 04, 2019, 09:48:51 PM »
I know theyíre a sponsor but if things are censored then how are they to know that they are getting so far away from their customers interests and loose touch with their great traditions that attracted me to them in the first place
Offline taw6243
« Reply #22 on: May 04, 2019, 09:54:49 PM »
Our reputation here at Silverwood Sawmill is our lifeblood and what has kept us alive as a business. Great value, service and attitude builds loyalty and commitment between customers and business. We want to use resharp services
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #23 on: May 04, 2019, 10:22:16 PM »
You made your Reply #11 on May 2nd which was a Thursday. (work day)  Did you make a call to Wood-Mizer to express your concerns?
Obviously, to me anyway, either you have a CBN wheel that is other than a 4į, or ReSharp inadvertently resharpened your blades on the the wrong machine that had a different (wrong) profile wheel.  Whatever happened, I feel that your call should have gone to Resharp.
Offline terrifictimbersllc
    • Terrific Timbers LLC
« Reply #24 on: May 05, 2019, 12:50:49 AM »
I agree, their 4 degree profile hasnít changed. The suspect blades returned from resharp could be checked with the woodmizer blade gauge which has the 4degree profile on it to see what profile it matches.
Also, a technical point, but it may be affecting this conversation, taw6243  hasnt stated that he is using a woodmizer wheel.
Offline taw6243
« Reply #25 on: May 05, 2019, 04:23:41 AM »
It is original one from Woodmizer and profile gauge shows it still matches 4 degree
Offline Nomad
  • Member
    • Bill's Mill Portable Sawmill Service
« Reply #26 on: May 05, 2019, 06:31:32 AM »
     Then it's possible someone from ReSharp mixed up the wheels they used.  Since you have a profile gauge, did you check one of the blades you received to find out what profile it was sharpened to?  It's also possible you inadvertently got somebody else's blades.  Stranger things have happened, I suppose.
WoodMizer LT50HDD51-WR
Lucas DSM23-19
Offline Jeff
  • Fearless Leader
  • Oh la di oh la da
    • Behind the  Forestry Forum YouTube channel
« Reply #27 on: May 05, 2019, 06:44:39 AM »
I can say this, is is certainly bad form to come on here and start spouting if you have not been on the phone with wood-mizer to figure out what was going on. Very bad form.
Offline taw6243
« Reply #28 on: May 05, 2019, 10:03:00 AM »
ThatWould be fine if they would answer the phone instead of just going to message and not getting a return call
Offline taw6243
« Reply #29 on: May 05, 2019, 10:04:26 AM »
And it was not just one call
Offline barbender
« Reply #30 on: May 05, 2019, 01:16:27 PM »
I will say, it is hard to get ahold of someone at Wood-Mizer when I call. I spend a lot of time on hold. However, when a tech answers the phone, they absolutely know what they're talking about👍
Offline Chuck White
  • Sawing Mobile since 2005
« Reply #31 on: May 05, 2019, 04:58:17 PM »
Just a suggestion:  Maybe it would be a good idea to get the phone numbers to more than one Wood-Mizer location!
~Chuck~
Retired USAF 1989, Retired School Bus Driver 2012, now semi-retired Mobile Sawyer, 2018 Silverado 4X4
1995 Wood-Mizer LT40HDG25 Kohler - Cooks Cat Claw Sharpener and single-tooth setter, 4-foot Logrite cant hook.
Offline WV Sawmiller
    • Green's Sawmill Services
« Reply #32 on: May 05, 2019, 09:27:20 PM »
   Good idea and suggestion. I think I have Indy, Atlanta, NC, Marty in PA and NY in my cell phone. They tend to back each other up. I'd call one and they'd be doing a road show or such and refer me to their counterpart who helped in every case.
Offline Bluejay27
« Reply #33 on: May 06, 2019, 09:31:48 PM »
Your machine may be misaligned. Although I will say I have felt the 10 degree profile varied slightly from my WM cbn wheel, but it sharpened fine for me
'98 Wood-Mizer LT40HDD42 Super, '08 LT40HDG28, '15 LT70HDD55-RW, '93 Clark GPX25 Forklift, '99 Ford F550
Offline taw6243
« Reply #34 on: May 07, 2019, 11:17:44 AM »
We were calling the resharp service for Woodmizer. And no cbn sharpener is not out of alignment
Offline Dana Stanley
  • For fun and profit!
    • Stanley Carpentry Construction
« Reply #35 on: May 07, 2019, 12:30:54 PM »
How many blades did you have trouble with? Maybe you grabbed the wrong blade, or do you only use 4*?
Making Sawdust, boards and signs.
Woodland Mills HM-126
Kabota B-7800 with backhoe and loader
Ford Ranger, Husqvarna 455 20", Mac 610 24", other chainsaws 14", 23 ton log splitter
Matthew 3:10
Offline MartyParsons
  • Wood-Mizer Service and sales PA, VA, MD, WV others
« Reply #36 on: May 07, 2019, 04:03:28 PM »
Hello,
   The CBN profile have not changed. 4/32 is still the same. It would be best to call the location that did your blades. You can also call Wood Mizer 1 800 553 0182.  If the issue came from our location in PA Call me.
10/30 is a close profile and sometimes is confused with 4/32 without using a gauge.
Marty
ďA pessimist sees difficulty in every opportunity; an optimist sees opportunity in every difficulty.Ē -Winston Churchill
« Reply #37 on: May 07, 2019, 09:20:17 PM »
Marty, Do the 8" and 5" CBN wheels have the exact same profile? Just a thought. I suspect a blade mix up is the problem though.
Matthew 3:10
« Reply #38 on: May 08, 2019, 07:00:06 AM »
Hello ,
   there would be no difference between 5" and 8" wheel.
Marty
Sharpening service?
Started by Lucman on Sawmills and Milling
Last post June 02, 2012, 10:21:25 PM
by Cutting Edge
question
Sharpening Service vs Sharpening myself?
Started by mviezner on Sawmills and Milling
Last post October 05, 2019, 06:38:33 AM
by Peter Drouin
Saw sharpening service near Camden SC
Started by milto on Sawmills and Milling
Last post June 01, 2021, 09:22:49 PM
by Jay B
Blade sharpening service
Started by stumpy on Sawmills and Milling
Last post February 22, 2005, 10:27:02 PM
by DR_Buck
