My first post , band sawmill blade question
Started by zombie woods, January 24, 2013, 05:30:29 PM
zombie woods
I salvage subtropical timber in south florida and the keys ,
mahogany , lycaloma/ wild tamarind , jamaca dogwood etc .
also have some inventory left over of hardwood I cut in Africa years ago .
the salvage florida logs often include tramp metal ,
and the African timber pink ivory african blackwood etc is just plain hard ,
Seems I sometimes  spend about as much time sharpening and setting as i do sawing
I have compaired many blades ,and the Lennox wood master c  7/8 pitch 7 degree hook , 0.045 thick with 0.022 to .030 set is hard to beat right out of the box , problem is I need a cam for the lennox blade on my old Woodmizer  automatic drag style sharpener , any one fabricating custom cams ?
Runing a WM lt40 with the 35 hp cat .
Tia
rooster 58
    Hi Zombie! Welcome to the forum. Go to the sawmill board and post your question there. I'm sure someone will be able to help you ;)
 ???  This is the "Sawmill" Board but there may not be many folks that has the answer to his question.
POSTON WIDEHEAD
Magic, early Zombie posted in the wrong place. Later the whole thread was moved here. That's why Rooster's reply reads like it does.  :)
OK, I found it "upstairs".   :)   That make two here, so no wonder I was a bit  smiley_dizzy
Oops, I see he did start a 2nd thread in the correct place.  :-[
I'll just lock this one and it can fall off the bottom on it's own accord.  ;)
