Author Topic: CSM: Shiplap - Rough Cut  (Read 1778 times)
Offline Lost in the Outback
« on: April 19, 2013, 10:09:39 AM »
Hello
Thank You for inviting me into your Forum. June, 1976 I started working full time in the bush and actually getting paid for it. Back then Dad always said I was getting a free education by working along side him. It certainly paid off. At 53 I waved good bye and retired. Now I'm busier then ever.
My question would be; Has anyone sawed shiplap with a chain saw mill? I constructed my own csm which works great.
I have an abundant amount of cedar logs and have been told I need to re-side my work shop.
Any advice would be appriciated.
“May your trails be crooked, winding, lonesome, dangerous, leading to the most amazing view. May your mountains rise into and above the clouds.”
Offline Jay C. White Cloud
  • semper fidelis
    • Online business card
Re: CSM: Shiplap - Rough Cut
« Reply #1 on: April 19, 2013, 10:25:46 AM »
Hi LITO,
Welcome to the FF!
CSM are wonderful tools, we use them often. However, they do have there limitations.  We tend to use them for timber frame work.  They do a really good job of making big beams, or making really wide cuts in locations that may be hard to access.  If you have to make many cuts, like making siding, they are very limited.  It can be done, but probably is not cost effective in either time or money.
If you are limited in not being able to get a mill to your location, and need to make siding, I would recommend just sawing boards, and not trying to bevel the cut in anyway.  Also, consider vertical siding.
Hope that helps,
Regards,
jay
"To posses an open mind, is to hold a key to many doors, and the ability to created doors where there were none before."
"When it is all said and done, they will have said they did it themselves."-teams response under a good leader.
Offline clww
  • Oh yeah? Watch this!
« Reply #2 on: April 19, 2013, 11:12:51 AM »
Welcome to the Forestry Forum. :)
The only thing I've ever milled with the chainsaw was either thick slabs or slicing logs into halves and quarters.
Many Stihl Saws-16"-60"
18-Wheeler Driver for Crete
Online beenthere
« Reply #3 on: April 19, 2013, 11:26:19 AM »
Lost
Welcome to the Forestry Forum too.
Would be interested to hear more about the shiplap, and how much lap you would like.
Which cedar are you planning to saw?
Pics of your csm would be great. We like pics. :)
Offline mesquite buckeye
  • Trees are good- even ones with stickers
« Reply #4 on: April 19, 2013, 11:39:47 AM »
Welcome. ;D
Offline millwright
« Reply #5 on: April 19, 2013, 07:13:50 PM »
I've made a lot of shiplap by using a dado blade on a table saw, it goes pretty fast and you can make any size lap.
Offline losttheplot
« Reply #6 on: April 19, 2013, 07:59:18 PM »
I have also cut a lot of ship lap on a table saw with a dado blade.
The mistake I made was using boards a full 1 inch thick.
I made vertical siding with a ¼ -3/8"th's reveal and the channel is ½" deep.
The shadow lines are so deep it just looks like boards with a ¼" gap.  :(
I had the same problem with my shop ceiling.
It's clad with 8" boards and again the reveal is so deep it's hard to see the wood at the bottom of the channel.
It is also a lot of wood to remove, the dry Douglas-fir took 3 or 4 passes for each dado.
Next time I would use ¾" boards planned to 5/8ths.
For exterior siding I would just cut 1" boards and install lap siding or board and batten.
If you have good western red cedar you can hand split 1"boards with a froe.
shakes go pretty fast with good wood, and make decent siding.
hope this helps.
LTP
DON'T BELIEVE EVERYTHING YOU THINK !
question
Shiplap
Started by Bandit on General Woodworking
Last post April 29, 2007, 05:45:52 PM
by Ianab
miles of shiplap
Started by hackberry jake on General Woodworking
Last post October 16, 2016, 08:02:26 AM
by Just Me
Making shiplap.
Started by Dave Shepard on General Woodworking
Last post May 01, 2021, 11:09:57 AM
by Bruno of NH
moved
MOVED: How Rough (Dimentionally) to Rough Cut?
Started by chet on Drying and Processing
Last post July 26, 2015, 07:21:13 AM
by chet
